997.2 c2 3.6L Y2009, aftermarket(DesignTek) Valvetronic Exhaust Vacuum line
You also installed Hi-flow CAT pipes,
I also want to install X-pipes to more sounds.
When I've installed DesignTek Valvetronic like you, I checked the valves on&off position operated with key fob properly before assemble it.
But I'm just curious about what valve's position is on or off. I know there is different between on and off.
Plz give me advices attached picture.
1) Long position of the valves is open status?
2) When I turn off engine, what is the valve position? long or short? or stay status I chosen.
3) Images of key fob, key locked means close / unlocked means open?
4) In my case, if that long position is open is right, my key fob functions are reversed I think.
Plz comment about these.
Thanks in advance.
Is this a open position? not connected status.
This is inside of valve description, long position is open?
When I started the engine(I do not push any button of my key fob), muffler valves are long position. If there is no vacuum, always long position?
Thanks in advance.
Is this a open position? not connected status. YES
This is inside of valve description, long position is open? YES
When I started the engine(I do not push any button of my key fob), muffler valves are long position. If there is no vacuum, always long position? YES
Thanks in advance.
1. Long position = no vacuum = valve open = loud mode; Short position = vacuum = valve close = silent mode
2. Within 15 minutes of shutting off the engine, the valve stay in the last position until vacuum slowly dissipate (leak) then the valve spring open. I always turn the ignition key to ON without starting the car the next morning then press the LOCK button on the key fob to make sure the exhaust is in silent mode before starting the car so it doesn't rock my garage LOL
3. Remote Key fob locked = valve closed, silent mode; Remote Key fob unlocked = valve opened, loud mode
4. Don't know what to tell you..... maybe you hook up the unidirectional bypass valve backward, I don't know ?
First of all,
thank you for your detail information.
Today I did check my engine area you mentioned.
I also think that "the long position" is valve open(loud sound mode). And it's off default mode when I do engine off.
But when I push the "lock" button of my key fob, the valve is open I think(refer to attached clip). I think the function of my key fob is reversed. lol.
I took a picture at my engine area,
plz give me an opinion about installation it is right or wrong. You mean that "the unidirectional bypass valve" is check valve(one way valve)?
Plz advise.
Thank you,
have a good one.
My engine area installed vacuum lines and solenoid.
Behind of solenoid.
The valve status when my vehicle off.
If your keyfob opens and closes the exhaust valves properly then I wouldn't worry about which button does which operation; however, an easy fix [in your case] is to take the key fob apart (you will have to do it eventually to replace the battery) and turn the button labels around.
Thank you for your advice.
My key fob opens & closes the exhaust valves properly. So I'll turn the button labels around you said.
You are a genius!!!
Have a good one.
You also have a DesignTek Valvetronic Exhaust like me, and installed properly I think.
I'd like to be advised by you.
Thanks in advance.
My engine area about setting.
