Cabriolet seals
Old Jul 15, 2020 | 08:19 PM
Ironman88's Avatar
Ironman88
Originally Posted by LexVan
Gummi Pflege smells soooooooo yummy. I want to mix it 50/50 with vodka.
Well, if you do, you won't have to worry about your gums drying out over time.
Old Jul 16, 2020 | 10:50 PM
Iceter's Avatar
Iceter
The only issue with buying a tube of gummi or shin-etsu is that you have to include it in your will. A regular-sized tube will last several lifetimes for the average automotive hobbyist.
Old Jul 18, 2020 | 12:37 PM
lexhair's Avatar
lexhair
Veteran: Navy
Originally Posted by Ironman88
I happen to have that Gummi-Pflege. The applicator is ridiculous.
As in "unnecessary" or "needs to be removed after the first use"?
Old Jul 18, 2020 | 01:15 PM
Ironman88's Avatar
Ironman88
The applicator is an imprecise way to apply / direct the product onto the various shaped surfaces. The applicator stays affixed to the bottle - meaning that you have the length of the bottle to contend with in trying to get into some of the tighter locations. I thought it was unnecessary at a minimum - but also detrimental to getting the job done.
Old Jul 18, 2020 | 02:53 PM
lexhair's Avatar
lexhair
Veteran: Navy
Thanks. Did you go with the ShinEtsu?
Old Jul 18, 2020 | 03:49 PM
Ironman88's Avatar
Ironman88
Yes. It's supposed to arrive later today. (Amazon.)
I understand that the size of the tube as it appears on Amazon is much smaller looking than it actually is. Will end up being a lifetime supply I think.
