Autel vs PIWIS II
I need a workshop tool which can code replacement stock components, as well as all the basic things from cheaper tools. I have narrowed it down to the Autel MS906BT or a Chinese clone of PIWIS II (my Porsches are 2009 & 2014).
Anyone got any views on this and any experience, particularly of the Chinese PIWIS offerings?
There's a whole thread on the Chinese knock off PIWIS -
https://rennlist.com/forums/997-forum/1176128-chinese-piwis-clone.html
I booted it on an old laptop and played around with it - tempted to get the hardware so I can do some coding...
https://rennlist.com/forums/997-foru...wis-clone.html
look into the fox well 510/520/530 units.
- no laptop needed
- $160 + i think another $50 (for some countries for porsche specific software)
- codes about 90% of what the durmetric Pro does (for 1/3 of the price)
- even codes modules that durmetric pro cant code (i.e. fox well can access + code the steering wheel module) - where traditinoally we would have to hunt down a piwisII for.
based on the large number of fox well threads here.
- dme scan
- obdII code read out
- steering wheel conversion (steering module coding + steering angle sensor calibration) - durmetric pro cannot access
- front module coding (turning side markers to blinkers)
- rear module coding (spoiler lift control)
- side module coding (using the keys to control the windows)
- getting horn to honk when unlocking the car (durmetric pro cant do this)
etc
can all be done via the fox well.
I would start with this unit first unless you absolutely NEED ALL the piwis functionality. cheaper, faster, easier, and off the shelf and ready to go.
- no laptop needed
- dme scan
etc
- no laptop needed
- dme scan
etc
- no laptop needed
- dme scan
etc
is your 997.2 steering wheel module new? if its a used module (or if u already have a 997.2) then you will have no problem re the fox well.
I have read in one case that the foxwell couldnt program a brand new steering wheel module (but i am not convinced it wasnt user error), despite the fact that that the user admits that the rear wiper module was successfully coded to function AND the steering angle sensor calibration was successfully.
easyPeasy. itll work np based on the videos I have seen with the fox well unit + 997MF enabling. i am sure u can find them via google
I’ve got the PIWIS 2 clone and running the OS on a VM. Works great if you don’t mind lugging around the unit and a laptop. It’s not the most intuitive of interfaces but it’s not terribly difficult either. Once you get used to navigating Around and figuring out where things are it gets pretty easier. Everything is organized by its appropriate parts group. I’ve both troubleshot a recoded a few things and haven’t had any issues. I’m happy with it.
