Fixed spoiler - check raised brake light
I installed a fixed wing with a third brake light and have been getting a "check raised brake light" error after disabling the OEM spoiler with Durametric Pro
One solution is to replace the harness with one from a car that has a fixed spoiler
I got another standard harness off eBay for $30 and followed jchapura's lead on modifying it.
The wiring diagram can be a little confusing so i tried to simplify it:
Pin A3 - BN - Brown - Chassis ground
Pin A4 - BN/OG - Brown/Orange - Ground for spoiler brake light
Pin A12 - BK/OG - Black/Orange - Ground for fixed 3rd brake light
The micro-switches are used to provide a "ground" when the spoiler is up or down to the opposing brake light. By by-passing them, you can wire the light of choice, or both.
I chose to do both.
Option 1: Fixed wing WITHOUT a 3rd brake light you need 997-612-670-71
OR splice BN/BK to BN on stock harness
Option 2: Fixed wing WITH a 3rd brake light you need: 997 622 670 70
OR splice BN/OG to BN on stock harness
Option 3: Fixed wing WITH a 3rd brake light - Splice both BN/BK and BN/OG to BN to utilize both 3rd brake lights
![](https://i35.photobucket.com/albums/d151/c_hundley86/Third%20brake%20light_zpsqyw9vswf.jpg)
Harness before:
![](https://i35.photobucket.com/albums/d151/c_hundley86/13EF9E71-D990-4696-A573-A55639DD20AE_zpsnufaqpm3.jpg)
Sheathing removed, wires spliced:
![](https://i35.photobucket.com/albums/d151/c_hundley86/6552ECA7-BEEC-4B76-9653-CC744E9A966C_zpsnyqzktze.jpg)
While I was in there, I cut out the wires for the spoiler motor and micro-switches, leaving only the fan, engine compartment light and brake light
![](https://i35.photobucket.com/albums/d151/c_hundley86/65A6B3CB-9AF5-4121-A9D1-9636E9D2B770_zpsdbx07aqz.jpg)
20 mins, some solder, and shrink wrap beats $140 any day
- If you have a fixed wing without a 3rd brake light you need: 997-612-670-71
- If you have a wing WITH a 3rd brake light you need: 997 622 670 70
I chose to do both.
Harness before:
The following 4 users liked this post by Clay.0:
So, just want to make sure my understanding is correct....I can replace the existing wiring harness which is throwing the error with 997-612-670-71 and not have to modify the new harness at all (car now has a fixed wing without a 3rd brake light). Want to confirm before I order a non-refundable part. Appreciate the information in this post.
IrishLegend (05-05-2021)
