Seat Memory Dysfunction - Need Troubleshooting Advice
I've read a ton of threads and tried all the various recommendations for clearing and reprogramming the keys and buttons all without joy. I also looked under the driver's seat for a loose connector on the control module. I did notice the the Memory 2 and 3 buttons do not work at all so I suspect a loose connection on the button module behind the door panel.
I decided to inquire with the Rennlist collective brain trust for troubleshooting advice before I start taking things apart. Thoughts?
Thank you in advance!
Scott
On my 997.2, the Durametric will read faults if there is a bad connection, pretty much anywhere. Not sure about the 997.1... maybe someone with a Durametric in Charlotte can help you out.
Regarding a loose connection at the control module.... try disconnecting and reseating it. I suspect it there rather than in the door as stuff gets jammed under seats all the time and nothing happens behind the door panel.
Peace
Bruce in Philly.
Peace
Bruce in Philly
I followed your suggestion and hooked up the Durametric; sure enough there was a C102 error. A google search revealed your post on this subject from Tax Day 2017. Following your lead, I raised the seat up and back, found the controller box and inspected/fiddled with the front connector and wires. Then I moved the seat completely forward and accessed the three connectors on the back. After dorking with them I cleared the fault code, took the car for a spin and then tested the seat memory functions: NO JOY! I returned to the garage and the Durametric showed that the error had returned. ARRGH.
I refuse to take this problem to the dealership so I guess that I'll find a wiring diagram and start chasing the CAN Comfort Bus. I cannot fathom that I'll be able to do much without pulling out the driver's seat; something that I definitely am not looking forward to.
Any ideas?
Thanks again!
Scott
