Alignment and balance
I live in a small town in Fl. The Porsche dealer is over an hour away. I want to play around with the alignment a bit. How do you find a shop that has the right equipment or skill to do it
If you put this exact search term into google you will get results from this site for what is recommended. If you add your city or the larger city you'll get even better results. Using AND (capital letters) makes the search boolean so you will only get what you are looking for
alignment AND florida site:rennlist.com (gives 755 results)
"alignment" AND "florida" site:rennlist.com (gives 687 results)
Thanks, that is good advice for my F150
. I was looking for some specifics on what users have found, such as the type of equipment the best shops use. Is there a national chain that is better than the others?
I basically have access to Tire Kingdom, Goodyear, Firestone, Sears and a bunch of mom and pop repair shops.
. I was looking for some specifics on what users have found, such as the type of equipment the best shops use. Is there a national chain that is better than the others?I basically have access to Tire Kingdom, Goodyear, Firestone, Sears and a bunch of mom and pop repair shops.
