Hockey Puck DIY - Jacking a Porsche 997
The pads I mention in post #11 stay in with a small twist. I’ve never had one fall out. You can leave them all in place and move your jack from jacking point to jacking point. They stay in place where you put them. I use them on my wife’s 997 C4S and on my 964 C2. A very nice product.
Can someone tell me why I would need 4 of these pads and not just 2?
FYI.... I know you all like pics of the hidden bits....
25mm X 33mm
Remember, the point of this puck is to have it inserted into the hole and stay there before I place the jack. Some of the other pads noted in this post are nice.... but not helpful as they don't hook. They have to hook first, then that makes placing the jack much easier as you don't have to find the hole via bendfing down, face on the cement, to see the hole. Doing it this way, hooking the pad/puck first (without looking), will prevent crushing/bending the plastic body bits.
BTW, a new hockey puck is literally $2.00.
Peace
Bruce in Philly
25mm X 33mm
Peace
Bruce in Philly
Thanks for your humor, it is very welcome.
I do find it funny how you manage to bring so many replies on a joke while others with genuine questions hardly get any response at all.
Cheers and good luck with your patent 😇
The liftbars seem nice too.....but I figure I'll get more use out of 4 Esco stands and two floor jacks for other stuff. The liftbars could only be used on the 997.
I know poor me still clueless as to where to put the jack stand even after reading the Pelican site.
http://liftbars.com/
Looks like a neat solution and should help show you where the 4 lifting pads are. The bars have a male post that fits into the female part of the pads underneath the car. Might be tough to see but if you feel around those areas you should find them easily. Drive up on some 2x8's to give yourself a little room to stick your head under there to see them?
Vincent713 (01-06-2020)
harborfreight jack and jackstands. You just need to do a full on dance to complete the process
1) Raise the rear and place stand under the front.
2) Raise the rear by the "suspension arm linkage subframe thingy" (you'll know it when you see it).
3) Repeat for other side of the car.
This is still 4 raises to put the car on 4 jackstands - not bad.
If you have in-place jackstands (like SafeJack or Jackpoint stands) or LiftBars, then you only need 1 raise per side.
I will only be needing the 2 rear wheels to be air born, 1. change oil, 2. replace spark plugs.
I think I got it figured out now, I jack up the front tires until the rear lifts up and that's where I would put the jack stand. Repeat other side and voila 2 rear wheels air born.
