I just bought myself a 2010 997 C2S and my mechanic told me that there’s an oil leak from the fuel tank. Any of you came across similar problems before? How should I deal with it?
I suspect there is a crack in the fuel pump housing itself, possibly at the base of the fitting the return line connects to. I had this issue with a fuel pump on a VW which is similar. Your mechanic should be able to quickly diagnose the source I would think.
Originally Posted by Theo Tse
I mean fuel. My bad I worded it wrongly. Will I need a new fuel tank? Thanks!
Did you check to see if the plastic screw down ring was tight? If it's tight and still leaking it could simply be the gasket in a best case scenario or the pump/tank in a worst case scenario.
Had something similar happen to one of my cars. The fuel sending/pump retaining ring was getting caught on a hose clamp and stopped turning. The previous owner/mechanic stopped turning the ring at that point. All that was needed is to move the hose clamp out of the way and continue turning the ring until tight. Should be a simple fix. But as others said, get it fixed immediately.
I have a bmw that started smelling of gas to the point that once I put it up on the lift I could see droplets of gasoline. Turned out to be one the plastic nipples/barbs was cracked. Once the car was turned on and the fuel pump started you could see gasoline spritzing all over the place. New pump and everything was resolved.
Seems like you should be able to figure out where it’s all coming from.
