Just Drove Tail of The Dragon!!
#31
Originally Posted by snaphappy
Ok I’ll check those out!!
Tonight I drove the new section of the Foothills Pkwy and I never saw another car. I’m getting better and more confident. Moving my seat forward really helped me in the corners. So simple but it helped a lot. Sports+ also really helps in the corners because it eliminates so much body roll. I also learned how low gears (higher rpms) render braking almost unnecessary. I rarely touched my brake. I’d downshift from 3rd to 2nd at the start of a turn and midway through I’d rev it to 5k (sometimes 6k) and exit the corner with zero body roll. It just felt amazing. Again I’m a noob and I have no idea what I’m doing.
I’ve heard the 991 PDK shifts faster...but I don’t know how. Occasionally there was that momentary lag, but for the most part, pulling a paddle = instant shift. It made feel so in control.
But honestly...here’s how good a C4S is in Sports+ with PDK... I’m a noob and I never heard a tire squeal. I never felt any imbalance or any fear. The car remained planted. It was really saying “I’ve got a lot more to give you once you learn how to drive.” Guys, I can’t say that about any American cars. They fishtail so easy, which is fun. But planted, in control, pushing the limit is MORE fun in a 911.
Respectfully.
Cw
#32
However Sport+ does change the PDK shift points, PSM engagement, throttle mapping and some say ignition timing. All of those would give the impression of a more taut and responsive car.
#34
No, he wasn't there that day. It was 55 degrees and there was no one on the dragon. About half way through I came up on a BMW motorcycle but he was going really slow for some reason. My second time through I saw a Cadillac sedan and Dodge Ram and both pulled over for me. It was really fun to have it all to myself. Probably for the best since I'm noob. I'm not sure I'll ever be there again. I mostly just drive my car around town. Rarely go above 2500 rpm in real life.
#35
PASM only has two modes and sport mode activates the sport mode in PASM unless you have the TPC DSC controller. DSC makes PASM activation separate from sport mode (at least in my V3 DSC controller).
It is interesting to see PASM is the same until you go into Sport+
#36
heres another old one. I cant get pictures on any of my old rennlist posts they must disappear after a time.
https://mbworld.org/forums/sl63-amg-...last-week.html
#37
Drove the Dragon several times with my 993's. The 997 I have only since 2 month as my daily. When I'm in the Smokey's we usually stay at the Snowbird lodge. This lodge is 20 min away from the dragon. I get up early and try to be there short after sunrise to avoid traffic. The 20 min ride to the dragon warms up the car perfectly. Doing then the 318 turns twice driving back and forth in one ride. Then back to the lodge for breakfast. Perfect start in the day.
#38
#39
#40
https://tapoco.com/?gclid=CjwKCAiA8e...xoCoQsQAvD_BwE
Tapoco Lodge is near top of the Dragon. Nice rooms or cottages, covered parking, good food.
#42
Here's the info I'm seeing about Sport mode. The dampers stiffen and provide better cornering: https://www.total911.com/porsche-911-gt3-first-drive/
Switching Sport mode on and off Switching Sport mode on and off simultaneously activates and deactivates the Sport mode in PASM.
If PASM Sport mode was activated with the PASM button, PASM remains active.
After the ignition is switched off, Sport mode is automatically reset to Normal mode.
#43
#45
J
