Arm rest Storage Compartment Lid
Old Oct 15, 2019 | 12:47 PM
PierW's Avatar
PierW
Default Arm rest Storage Compartment Lid
Hi all...
I have searched the threads and can't seem to find anything addressing this issue, so if I missed it, please feel free to pummel me (and afterward, point me in the right direction please?).
'07 997.1 and the spring-loaded hinge on my arm rest storage lid broke. Can't seem to locate anyone who may have had the same issue, parts, DIY's or anything that could get me moving in the right direction. If no prior posts, does anyone have any experience or insights into this issue? It's not the end of the world, but I hit it from time to time getting out of the car and it flops up and back down.
Thanks.
Old Oct 15, 2019 | 01:08 PM
Zettinger's Avatar
Zettinger
Originally Posted by PierW
Hi all...
Thanks.
It should be 99755343900
The question is rather, is your console attach point broken?
I had it removed when I repainted the middle console.
To replace the spring, I think there were a few screws on the bottom side on the middle console. this means the console needs to come out for this.
Old Oct 15, 2019 | 02:32 PM
voiceprint1's Avatar
voiceprint1
I have a buzz coming from under part 25 on the PDK shifter, thoughts? do I have to tear the whole thing down?
Old Oct 15, 2019 | 02:52 PM
Zettinger's Avatar
Zettinger
I assume you mean the panel between shifter cover and console.
This piece (24 in the picture) has two hinges on the outer sides what need to clip in the console. On the front side there are four screws connecting it to the middle console.
To get this out, you need to remove shift boot, panel under shift boot and "maybe" the sides on bolsters on the PCM stack. I removed it since I re did the whole interior.
Old Oct 15, 2019 | 03:01 PM
voiceprint1
Thanks for the reply, it's intermittent (of course), maybe I will ask my body shop if I need work done, I think I would bend or break it further.
Old Oct 15, 2019 | 05:13 PM
318touring's Avatar
318touring
I just put a small, thin rubber wedge between part 25 and the carpeted tunnel. I did have to remove the small carpeted section that screws into the centre console first.
Old Oct 22, 2019 | 01:11 PM
PierW's Avatar
PierW
Thanks Zettinger...I was actually referring to the hinged lid on the interior of the door panel/arm rest. Not sure if perhaps the prior owner torqued it getting out of the car, but it actually broke the plastic hinge mechanism closest to the dash.
