NB wheels for WB car
Fronts are the same
Rear offset is 51 for wide body and 67 for narrow body. If these are OEM then a 16 mm would take you to stock.
But there are OEM 5mm spacers so you could go to 21mm spacers of you wanted.
However, I would go 25mm in the rear cause I can't stand a car with the tires sticking out, and anything thicker than 10mm out back on stock wheels, sticks out with 305 tires. For the front, I went with 5mm and glad I didn't go thicker.
my C4S has 19x11 et35 with 305 in the back and i think i could get away with another 5mm easily. in your case i would go 30mm in the rear (et67-30mm = et37 which is less aggressive than my et35)
