Seat rattle fix
Seat rattle fix
I’ve seen a few threads on this here and there, and have had this issue on my car since I got it last year. The driver’s seat clunks under heavy acceleration, braking and while getting in and out of the car. It’s been driving me crazy.
I finally took a look under the seat the other day and fixed it with a pocket screwdriver and a 10mm wrench.
Pop off the little plastic cover that uncovers this bolt and tighten it a bit.
Here’s the other side for reference. It’s a T30 torx, but it should stay still when tightening the nut on the other side. Make sure not to over tighten it as it can actually impede the raise and lower seat adjustment if the plastic bushing is squeezed too tightly.
Anyways, hope this helps!
Thank you for posting this! The issue has bothered me on my old 996 and on my 997, and the dealer can never figure it out.
Gnarlycharlie (07-15-2019)
Thanks man !
I'll check that, I have the symptom on heavy breaking with the seat trying to move forward with my 100 kg on it.
Also do you guys suffer from passenger seat noise ticking when the seat is empty on bumpy road ? It is driving me nuts , as soon as I hold the back of the seat it stop... may be related to parts of release mecanism moving...
Thanks man !
