Saving Readiness / Codes Monitors during battery swap
Have you used a cig lighter plug in "charger" to save the readiness codes / monitors when swapping a battery?
Which one worked for you?
Please only reply if you know it works from actual experience.
No guessing :-)
Craig
No guessing :-)
Craig
This not the answer but after 3 or 4 days of driving under different conditions the readiness codes will be re-populated if you are concerned about passing emissions inspections.
