Is my toolkit missing items?
Old May 6, 2019 | 09:09 AM
lmaternick's Avatar
lmaternick
Your wheel lock socket (it's there so relax) is the only thing in there you'll really need outside of your home garage in a bad situation. Even the tow hook should never be required unless you have an unfortunate meeting with a ditch. Never use that tire goop....ruins tires for good and requires tire shop maintenance to clean up before installing a new tire.
I have used the compressor before on a slow leaking tire that took in a screw.
I miss the tool kits that BMW's have in the trunk.
