Roll Bar
Old Apr 30, 2019 | 05:05 PM
Joehatz's Avatar
Joehatz
Default Roll Bar
Has any one fitted an Agency Roll Bar to a 997 Cabriolet.
Agency says it will fit with top down but may have issues when the top is raised.
I am wondering if the roll bar can be installed when the Top is up, Agency could not confirm this.
It would not be necessary to raise and lower the Top when it is installed and can be removed when not needed.
Old Apr 30, 2019 | 08:57 PM
shekmark's Avatar
shekmark
Did you happen to look up DAS roll bars? They make a bolt in for the cabriolet and the top works fine. I hear you give up a little leg room if your long legged.
