Shifting
Old Mar 30, 2019 | 01:51 PM
avonted's Avatar
avonted
Default Shifting
Manual C4 here. I have a theory that I wanted to run by the group. Last year I aligned my shifting cables and they were pretty decent. Over the winter I installed new engine mounts and now the shifting is not so great. Do you think the engine mounts shifted the engine, and trans, slightly so now it should be realigned?
I have also wanted to change the manual trans fluid with hopes it would help a little too.
Looking forward to you $.02 - tia
Old Mar 30, 2019 | 03:07 PM
kisik's Avatar
kisik
I think old old engine mounts introduced a lot of flexibility/movements. I would compensate for some cable trany/engine interaction. If you installed semi solid engine mounts like RSS (I hope) it would explain due to extra rigidity My theory.
Old Mar 30, 2019 | 04:11 PM
avonted's Avatar
avonted
Thank you. So would you agree to readjust the cables and change manual trans fluid?
Old Mar 31, 2019 | 01:21 AM
kisik's Avatar
kisik
You can try re adjusting again. Do a small change, a click or two. Go for a few days and check. When cold, the first gear will always be slightly more work to engage. Be gentle and patient. You can change tranny fluid. Porsche only.
Old Mar 31, 2019 | 01:55 AM
rw229's Avatar
rw229
I replaced my 10 year old, only 25k mile mounts with some RSS semi-solids. I immediately noticed the car seemed more "connected". I had to adjust my shifting a bit due to what I assume is the extra rigidity and the engine flopping around less.
That said, I don't think the shifting has degraded at all, though a little different and a bit more sensitive to throttle / clutch input.
Old Mar 31, 2019 | 10:19 AM
avonted's Avatar
avonted
I ordered the fluid and will do a change as soon as I get it. I will also realign the shifter. These things, on top of the NE Ohio weather getting better (hopefully sooner than later), I am sure will make a difference.
