997.2 coolant fill frustration
I have used my Airlift to vacuum purge and fill my Cayenne several times (Waster pump replacement, coolant T's etc) and never had an issue getting a solid 20 inches of vacuum and a complete coolant fill in one pass. Things didn't go as well with my 997.2 Targa. I just installed new CSF center, left and right radiators. When I drained the original left and right radiators to remove them I got about 5 quarts of coolant out. I put the new radiators in empty and buttoned everything up. I then hooked up my Airlift to purge and fill the system. I only got to about 5 inches of vacuum when coolant started spitting out and by the time I got to 10 inches of vacuum (about 20 minutes) I had pulled out almost 4 more quarts through the Airlift. I shut the purge valve and it held the vacuum at 10 inches for several minutes and the hoses were mostly collapsed. At this point I figured that with so much coolant still in the system I wasn't going to be able to get a solid 20 inches of vacuum and full fill done with the Airlift. I tried and I was able to get about 5 quarts back in with the Airlift. I started the car up and let it warm at idle with the cap off hoping the air would purge out but unfortunately by the time the dash temp gauge read normal (175) the reservoir was overflowing coolant like crazy. At this point I shut it down and let it cool for a bit. A few hours later I topped up the reservoir and took it out for a drive (staying close to home) hoping this would get things flowing but by the time the temp came up I could see coolant steaming off my exhaust and my check engine light came on. Temps never rose above 175 and my oil never got above 200 by the time I pulled back into my garage. I let things cool down again and tried the Airlift one more time. This time I got to 10 inches much more quickly but again started pulling coolant more then purging air.
So I am looking for advice on what to do to get my coolant system purged at this point. I am thinking I may need to drain the engine side of the system (pull the coolant hoses) and try to purge again with a lot less coolant in the car (book says 8.3 gal) is full so about 7 gal still in) but I am open to ideas. Anyone else have an issue like this? Thanks
Jeff
Jeff
I was told that whenever radiator flush/refill is needed, a systematic procedure involving instructing the car's computer is required, and yes unfortunately, it is typically done by Porsche dealerships for around $400-500. The procedure involves the opening and closing of several valves in series that control the flow of coolant to and from the radiator in the front of the car and the engine in the rear. I have not seen a DIY procedure to properly flush radiator fluid for a 997.2 otherwise, and if someone does know how, I'd appreciate if they could share that information.
I’ve used the airlift on my 997 a few times and I’m not sure why you can only get to 10 psi with the hoses collapsed. However, it sounds like you still have air in the system when you ran your car. Doesn’t appear that the coolant was circulating and that is what you saw when ithe expansion tank over flowed. I know my 1.5 gallon compressor is too small for my airlift to function properly and I have to use my 8 gallon but since you were successful with your Cayenne I doubt that is the issue. I’m still trying to figure out why it looks like you purged the system but still have air in there.
- Remove rear underbody panelling
- Open the cap on the expansion tank and remove it
- Unscrew the drain plug (hexagon socket) on the coolant guide tube
- Unscrew the drain plug on the thermostat housing
- Collect emerging coolant
- After draining the coolant, screw in and tighten drain plugs with new sealing rings. Tightening torque: 25 Nm (19 ftlb.)
- Pull off large coolant hoses and heater hoses
- Refit coolant and heater hoses after draining coolant. Coat O-rings and coolant hoses with Klüber Plus Gel (Part No. 000.043.205.93).
- Pull a vuccum to .85 bar (Arilift says 20-25 inches) with a venturi nozzle tool (e.g. Airlift or Porsche special tool filling device 9696
- Confirm vacuum holds for at least 30 seconds
- Open inlet side of Airlift to pull in coolant till vacuum reaches zero
- Test drive the vehicle. Following the test drive and when the engine is still at operating temperature, accelerate briefly to 6,000 rpm a number of times at idle speed in order to fully ventilate the system
- Check the fluid level with the aid of the markings on the expansion tank. Correct the coolant level after the engine has cooled if necessary
Jeff
It is nearly impossible to to completely drain the 997 cooling system or a least it is very difficult. Perhaps I’m wrong but the point of an airlift is the negative pressure draws out the air trapped in the system so I cannot see why the system needs to be fully drained for the tool to work properly. When the dealership changes the coolant I don’t think the drain 100% of the old fluid out and I’ve not heard that a computer was invloved in filling but again I could be wrong.
Jeff
On my 997.2 I tested it for leaks and had no issues holding like 25 inches of mercury. That said I am using a 50 gallon compressor at 140 psi. On my other cars that did have some air in the system I had to use the airlift 7-8 times to get to 25. I hooked up the airlift and opened the valve until the compressor turned on. I then shut the valve and waited for the compressor to go back up to 140 psi. Repeat 7-8 times. The less air in the system the less you need to repeat the procedure. Remember to get to 25 it will be exponential with regard to time. The Porsche had no air and only took 2 times to hold 25.
I'm from the 996 side. But as a mechanic i can tell you that you cannot use an airlift with any large amount of coolant in the system. It will constantly pull coolant out of the system and you will never be able to obtain more the 20 inches. At this point you still have air in the system which is causing your issues. On the 996 it is easy to disconnect certain hoses and blow a small amount of compressed air to completely drain the system.
I have also read that on the 997.2 you should not drive it until air is completely removed from the system as it is prone to overheating which can cause a situation in which would require a rebuild.
When I had to empty my system after draining the coolant I kept hooking up the airlift and running a vacuum and each time I could drain out more coolant. I did this about 5 times and then used a leaf blower on the 1 1/2 inch coolant tubes that lead back and forth to the front radiators.
Issue solved!
Thanks everyone for your input and ideas. Everything is all set now. and I was able to get the coolant completely filled and the air out. The solution was to pull the two drain plugs at the engine and pull the two rear main cooling hoses on either side of the transmission. This drained another 2 gallons of coolant and when I hooked the Airlift up this time I was able to get a solid 25 inches of vacuum in just a couple of minutes and 5 gallons pulled back into the system no problem. For those looking to do this here are some lessons learned from my experience and from talking this over with the shop foreman at Porsche of Tyson's Corner:
Jeff
- The 997.2 and newer models are much more difficult to purge then previous models and while you may get away with small amounts of coolant removal, air pockets created in the radiators are the hardest to get out.
- Safest bet anytime you have to drain some coolant out for a service (especially at the front of the car) is to just to a full drain and then purge and fill with an Airlift
- The only special tool needed is a a vacuum tool (Airlift, Porsche special tool or other venturi device)
- Airlifts don't work well trying to pull air from the front of the car through gallons and gallons of coolant near at the back of the car near the reservoir!
- The drain plugs on the block are both the same and are made of the same soft aluminum as other drain plugs so be careful and make sure your 6 mm hex is fully seated or they will strip.
- The crush washers are supposed to be replaced when pulling the coolant drain plugs but once crushed they do not want to come off the plug. Porsche of Tyson's did not stock the plugs. The crush washers were so hard to get off without damaging the threads of the plug that next time I would have had new drain plugs and washers on hand before I started so i could just replace the plugs.
- You will want to open the air purge valve on top of the coolant reservoir tank as soon as you start draining coolant and leave it open while you evacuate the system with the Airlift, filling the system with new coolant, warming up the system and test driving the car.You can close it the next day after a full heat cool cycle if it has not already closed on its own. The valve is designed to open and stay open when the coolant is at operating temps and close when the coolant cools. It is supposed to open past the manual open position when hot so it should effectively override your locking it open and self close
Jeff
lostdog (03-03-2020)
