Air Oil Separator
Old Jan 27, 2019 | 12:06 AM
tophand576's Avatar
tophand576
Default Air Oil Separator
I've seen this referenced in several places, but not sure if I have a clear understanding. 2009 C2 3.6L PDK. While replacing the air filters today I noticed the Throttle Body was pretty dirty so I opened the valve with my hand and noticed it looked wet inside. I then cranked and let it run for a few minutes, and opened the oil filler cap, which resulted in an immediately worse idle. Very rough and nearly stalling. Is this the sign of a bad AOS? It also smokes a lot upon start up and smoke for several minutes. Thanks for any advice. This is my first Porsche that I've had for about a month now.
Old Jan 27, 2019 | 12:43 AM
TheBruce's Avatar
TheBruce
Welcome and congrats on the new 997! Sorry about the AOS. They are known to go. How many miles on the car? From your description it sounds like all the symptoms. Was there a lot of suction when removing the oil cap?
I dont know about on the .2, but on the .1 they are not that hard to replace. I think the part is under $200.
Old Jan 27, 2019 | 01:47 AM
Wayne Smith's Avatar
Wayne Smith
The AOS on the .2 was redesigned and very unlikely to fail. What you're describing sounds normal. You can check it with a vacuum gauge.
The smoke on start up is most likely due to parking on a side to side slope. With the flat six, oil is sprayed onto the piston skirts. When you stop that oil lays in the cylinder on the crankcase side of the piston. If on a slope, that oil runs onto the piston rings and over time through the rings and into the combustion chamber. And yes, it smokes when you start it again.
Old Jan 27, 2019 | 02:51 AM
TheBruce's Avatar
TheBruce
@tophand576 - Wayne is my 997 yoda. listen to him, not me :-)
Old Jan 27, 2019 | 10:45 AM
Bruce In Philly's Avatar
Bruce In Philly
2009 C2S 130K miles.
I don't think my car has every really "smoked".... maybe a few times but it is hard to know the difference between steam and oil smoke. But... as Wayne noted.... I am always on flat ground. In my old Boxster S, I would get smoke on startup from two conditions (I had that car for 197K miles) 1) parking on a slope, 2) Starting and shutting it down real fast. Regarding no 2, for some stupid reason, I would park and shut down the car. Then start it up and shut it down withing 2 -15 seconds say to move it a few inches. This appeared to leave oil in the heads that then got blown out on next start up... Maybe the computer delays ignition for a half turn to squirt oil in there and the double shot of old and new gets it to blow through... I dunno, I can make stuff up all day, but that quick on/off definitely made smoke the next morning.
Flat 6 engines don't rely solely on gravity to remove oil from the heads, notice in the diagrams there is a sump pump in each of the heads to remove excess oil. Odd that Subarus do no have these pumps.
Peace
Bruce in Philly
Old Jan 27, 2019 | 11:17 AM
tophand576's Avatar
tophand576
Wayne, I park in my garage on a level surface and at work in a level parking lot. It smokes a lot (to me) every time I start it.
Old Jan 27, 2019 | 11:18 AM
tophand576's Avatar
tophand576
It's alway parked on flat ground, in my garage or at work. It smoke s lot every time I start it.
Old Jan 27, 2019 | 11:44 AM
Bruce In Philly
Any ticking? This is a bit scary to think about given our 9A1 (997.2) engines make a weird set of noises if you listen carefully including ticking and tacking. There are some vids out there with recordings of piston slap... not a good thing... maybe pull up a few of those. Again, careful about jumping to conclusions... our engines make some weird-*** noises.
Peace
Bruce in Philly
Old Jan 27, 2019 | 12:03 PM
tophand576's Avatar
tophand576
I'll look for some videos on that. Once it warm up and the idle settles back down it "seems" to sound OK, but I don't really know what normal is. My local service shop told me it was running like it should.
Old Jan 27, 2019 | 12:18 PM
Balr14's Avatar
Balr14
My 09 C2S (54k miles) makes a lot of noise, hard to tell if it's ticking or just general clatter. But the indie, dealer and tuner I take it to all say it sounds great and I should track it because it runs really strong. It certainly makes a lot more mechanical noise than any other cars I've owned in recent memory, even a Forester XT.
Old Jan 27, 2019 | 01:31 PM
Wayne Smith
Have a mechanic listen to it and do a vacuum test for the AOS. Anything that works can fail!!!
Do you burn oil and need to add between changes? I don't know if this really matters, but it is possible.
My driveway curves and slopes. If I park on the side sloped section (just moving the car or after a long drive) it smokes like a thousand camp fires on a rainy night. This lasts about 20 seconds which in dog years is like 2 hours. It takes minutes for the air to clear. At sunset it is most impressive.
So I don't park on the slope unless my garage is acting as a wood shop (or tile cutting shop for the last week). Yep, off topic.
Even with this smoke screen occurring on those rare occasions, without adding between changes I've had 7.5 quarts out and 7.5 quarts in at every 5K mile oil change over the 85K miles of my stewardship. So it is annoying but not a problem (environmentally debatable and definitely embarrassing).
Are you sure it's oil? Definite blue, or more white? Does the ambient temperature affect this? Does this happen after a quick on off, like filling with gas?
