Chime on above 75MPH
Just replaced my PCM2.1 with an Alpine iLX-207 HU and the HUR NAV-TV210, 2008 997TT with the Bose Amp.
Now I have my seat-belt chime coming on at 76MPH and off at 71 MPH WTH!!!
Anyone have any thoughts I have a Durametric Pro and went into the instrument cluster and turned all the chimes off.
Another interesting thing the car is equipped with the Sports Chrono it hasn't worked since i purchased the car in August 2018 now it does work.
Could this be coming from your new head unit. I know some of the newer head units will give you a chime if you exceed the speed by a certain amount. Have you checked the limit indicator on the dash to make sure it's turned off. I have my limiter set for 65 mph, but it only chimes once when I exceed the limit.
I pulled the Alpine and drove with the stock PCM an no PCM, no change. Must be a malfunction of some kind.
I also removed the factory XM, 6CD changer and NAV system don't think it has any affect as its fiber optic and power. Looped the Bose amp back in.
Is it possibly the speed alarm got activated at 75mph in the PCM settings. When I bought my car is was set at 80mph but I deactivated it.
That's a good observation, I barely used the PCM as it it very dated interface,however I had no chime before I replaced it with the Alpine unit.
Do you have a pic of where to find it I can reinstall the PCM once again.
SOLVED!!
Reset the ECU and all good now.
I believe it's under instrument cluster like resetting the service light, I was using the durametric pro. PM me if you still need help.
