replacement tires
replacement tires
I have centerlock 19 inch wheel low profile that makes city driving uncomfortable. Can car accommodate higher profile tire ? If so what size ? rear current 305 30 19
look at the specs for 305/30/19 and find a tire with near as possible overall diameter. You have to use a 35, but youre going to be pressed to find one with near same diameter
Received 5,410 Likes
I bet your tires are over inflated. Start there, and see if your ride improves. GL and welcome to RL.
you need this, it changes the comfort of the ride significantly (im assuming your car has PASM).
DSC Sport V1 Plug N Play Controller
https://www.dscsport.com/porsche/#997
You can usually find them used for about $900 in classifieds
What are your tire's DOT code dates?
