will 2006 911 rims fit a 2011 base carerra
looking to soften the ride of my fathers 2011 911 (base carrera) currently OEM running 19" rims. will the OEM 18" rims from a 2006 997 plug and play?
the tire dimensions seem to be the same on the 18's:
235 40 18 front
295 35 18 rear
TIA
235 40 18 front
295 35 18 rear
TIA
You didn't mentioned rim's sizes. If it 8" front and rear 10" then 295 tire would fit (on a higher range) but ideally you would want 295 on 11" from C4 with ET51 to fit perfectly flash. Overall you are fine.
car currently is running:
235/35-R19 front
295/30-R19 rear
so the same width between the 2006 rims i was asking about (both 9.3" wide/front and 11.6" wide rears)...which seemed to make sense to me. just wanted to ask before making the swap. this is our first Porsche.
235/35-R19 front
295/30-R19 rear
