05 997.1S sooty left pipe and idle ticking noise
Dear rennlisters,
My 2005 997.1S with 48000 miles has recently started with a few symptoms that im really worried about.
1- driver side (left exhaust tips) have become more black sooty than left ones. I heard This sometimes can be normal, sometimes not.
2- The engine started to have a tapping noise in idle (both hot or cold), if i leave it it neutral and increase the rpms the sound will tapping noise will sound faster.
3- i’ve found out that if i floor the car, a slight burned oil smell can be felt.
4- in terms of performance the car runs really well and normal. No performance loss.
5- I have been monitoring the oil consuption, which so far seems normal. 0.4 quartz in 400KM
6- Gas efficiency is 13km/100liter
Any ideas of what could this be? Spark plugs, valve lifters, air oil separator?
please dont tell me this could be bore scoring problem and i will have to rebuild the engine.
here is a video from another user with the exact sound.
That oil consumption would be concerning if it was my car. .4 quarts for 250 miles is still within the Porsche standard of 1.5 liters per 622 miles, but I have never known anyone to burn that much oil without there being a problem.
Pop off the AOS intake to plenum tube (gently) by squeezing the tabs and see if oil is pooling there. The AOS vacuum source is across from the right bank so it gets pooled oil first during intake as it’s straight across.
Could be AOS + noisy lifter.- could be the other thing you don’t want to talk about.
Good luck! Keep us posted!
My '05 (non-S) had only symptom #2, starting around 60K miles. Shop found bad lifters. As my 3rd-party warranty was due to expire inside a year I opted to delve further rather than just go with a lifter job, and it was discovered it had that thing you don't want to hear about. However it wasn't visible with a scope through the plug holes because at that point it was just the piston skirts that had begun to wear and tip/slap (which was what made the ticking noise), the cylinder walls were as yet unscathed. It was only discoverable from underneath.
I don't have firsthand experience doing it, so this is speculation based on general knowledge. I would think one might get eyes on the lower (well, inboard on a flat engine design) cylinder walls with the pan off and pistons at the top of their stroke, although whether it would be possible without a camera I don't know but renting one shouldn't be a big hassle. However, getting a look at the piston skirts I doubt would be possible because AFAIK they don't protrude from the cylinders at the bottom of the stroke. That's what was knackered on mine. The cylinders had not scored yet.
Fiberoptic camera that attaches to your cell phone is available for around 30 bucks on Amazon. I have one and you can use it to take photos or videos in 1080p. If you're going to drop the pan to scope the cylinders, might as well get a camera to do it yourself.
Thanks Jeebus31. I will get a camera for my phone.
I have this one and it’s great.
Thanks for the feedback guys, as suggested i will take my car to my local shop that maintains the 997.1 gt3 cup cars.
they should be able to diagnose this.
i will update soon 🤞🏻
