So I finished off another little mod to get a step closer to my all black interior. I had the A/C vents painted in piano black to match the center stack.
It took my paint guy over 1 hour per vent to get everything ready for painting but I love the way they have come out, he said if he tried to pull them apart he will break some of the clips that hold the silver piece of the vent onto the body.
Getting them out of the dash was easy, I just used two metal picks, pulled down on the tabs and gently pulled away from the dash so as not to damage the leather. It had also been bothering me that the adjusters were broken, I had to use a pencil on the two side vents if I wanted to adjust the lateral movement, of course the small plastic clip is not a part you can order from Porsche and after seeing second hand vents cost upward of $80 each, I though I would knock up a couple of them with my 3d printer.
So everything turned out as it should, vents move as they should and at the fraction of the cost!
I like the 3D printing. When I was doing my upgrade from the charcoal colored vent surrounds on a base to the alumalook on the S, I bought so damaged ones and swapped. If I recall correctly, it was a gigantic pita to swap them. I think I broke only one tab, figured worst case I'd glue them all back together but there was no need. If you make more of those 3D vent movers, I'll take some off your hands
That piano black does look great! If you do print up any more of the adjusters i’d Be happy to buy a few; I have the same issue with all of my vents. 😡
Very nice and a job well done. I really like the blackout look and you've now got me thinking. I also have access to a 3D printer at work so I've made a mental note to keep that in mind if I have broken bits that need replacing. Thanks for the post and the pictures as this is the type of information that is really educational
