Are there exhaust gains?
is it worth going to aftermarket pieces? Are there any real power gains to be had? I was going with Fister just for sound, but is it worth a bit more to go aftermarket? I do have the evoms intake (also for the sound)
you get very little hp from hardware. only when you add the ecu tune do you get benefits from the hardware. If you get more intake and exhaust air flow, the engine doesnt utilize it unless you have a tune that tells the engine to utilize it
mike
I've installed a Tubi exhaust approx 12 months ago and did it purely for sound. The manufacturer claim 20bhp, which equates to a 5% increase in bhp. The bum dyno says something has changed but it's negligible.
Do if for noise only otherwise you're going to be disappointed.
You are correct, however, okbarnet has a point also. At wide open throttle or somewhere near it, the ecu resorts back to open loop and the engine is fueled and timed only by its pre-programmed tables. The question is does Porsche have any allowance written into the factory tables when addition airflow over factory max is measured via the mass air flow sensor?
mike
Depends.... what year/model is your car?
If you have a 997.2, like I do, Sharkwerks claims 12HP 14TQ and have dyno plots..... I am pretty sure they used to claim 18HP no? hmmmm.
http://www.sharkwerks.com/products.php?pid=193
Anywho.... I can't tell the difference. Sounds nicer without being loud.
Peace
Bruce in Peacy
Peace
Bruce in Peacy
Can’t say, but my 991.1 has a Sharkwerks X Pipe (just a replacement of the large center muffler) and when researching various brands who make said X Pipes, I saw gains claimed as high as 35 crank HP. Lol. I’d be happy if it gives 5. But in reality it’s all about freeing up that addictively glorious sound. And in that sense, it’s beyond worth it.
There are limited gains to be found either with software or hardware on a naturally aspirated 997. But it also will depend on which model you have. The engine is mostly just a vacuum pump so improving how easy it is for the engine to breathe (intakes, headers, exhaust) can help make more power. Porsche has choked down some of the engines more than others. It would be easier to find power from I/H/E changes on a base model Carrera than a Carrera GTS, for example. The base models are more restricted when it comes to the headers and intake. For example the Carrera GTS comes with a larger throttle body in the first place, but this is something you can buy and mod in the aftermarket for a Carrera or Carrera S.
Either way if modding for power gains there are much better cars to do it with.
I know this is not exactly on topic, but aren't aftermarket exhausts typically a bit lighter weight?
i second that, but don't forget..Sharkwerks center muffler bypass saves about 15lbs.
Peace
Bruce in Peacy
Peace
Bruce in Peacy
No offense but the sharkworks performance page is full of so much bs its hard to count it all. And unfortunately because of that trusting their dynos is hard for me especially when you know you can strap your car down for 10 runs and see 20-30 hp differences without changing a single thing.
mike
mike
