Torque wrench suggestions
Old 06-10-2018, 08:06 PM
GSXR750
GSXR750's Avatar
Default Torque wrench suggestions
Hello All,
In prepping for my upcoming track day thanks to you guys I've got my stuff ready to go with the exception of a torque wrench.
any thoughts?
thanks
mike
Old 06-10-2018, 09:02 PM
dgjks6
dgjks6's Avatar
Autozone. Cheap and guaranteed for life. But the brand does not matter as much as the accuracy. So get one of these:
https://www.homedepot.com/p/Powerbui...0962/203117027
That way you know you are calibrated
Old 06-10-2018, 09:18 PM
bhvrdr
bhvrdr's Avatar
Yup home depot husky. I have all three. Lifetime guarantee and all you do is walk in and walk out with the replacement. Kobalt from lowes are only guaranteed for 5 years but the rest of their hand tools are lifetime. Thet have some cool zero clearance pass through wrenches that are nice to have for swaybar links and the like
mike
Old 06-10-2018, 11:49 PM
ColoradoMark
ColoradoMark's Avatar
Old 06-11-2018, 07:19 AM
sober_owl
sober_owl's Avatar
1st u need to ask why u need it? if its for tires make sure u get one that has the range u need... like 20ftlbs to 120ftlbs for small engine bolts the smaller ones are more accurate than a bigger one set to its lower setting.. for tires just get a 30 dollar craftsman..
Old 06-11-2018, 10:10 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,420 Likes on 862 Posts
+1
I am just a hack, but I tried the cheapo brand, a Brownlin electonic one, and now settled on two Craftsman (non electronic) that I really like (one for higher torque, like suspension and wheel lugs, and the smaller for drain plugs etc.).
The cheapo worried me, the Brownline was awful.... the batteries kept dying, the torque values would time out and constantly had to reset it.... just crap, and I would blow by the beeps all the time. You will need to consider 3/8" and 1/2" and then your socket sizes, and then adapters. Remember to "zero" them after every use. For lugs, get a good impact socket set because if you continue to wrench, you will end up buying an impact gun... a slippery slope item.
Peace
Bruce in Philly
Old 06-11-2018, 10:12 AM
Petza914
Petza914's Avatar
Received 6,172 Likes on 3,936 Posts
I have 3 of the Snap-On Digital Micro Wrenches. Set the torque you want on the screen and wait for the beep and slight vibration to know you've hit it. The newest one, which is an 1/8" has an LED array on the side so even if you're in a position where you can't see the screen, you can see the lights work their way up from green to yellow to red and know you're closing in on the value before the beep and vibration. The other advantage to this series of wrenches is that some Porsche fasteners, like those on the engines require a force value, then X degrees of addition rotation be applied for proper tightening. These have that setting and capability as well. The SnapOn wrenches also come with a calibration sheet to show you when they were calibrated and by whom at the factory.
Also, if you need a torque wrench for wheel bolts, getting one that only goes to 120 ft.lbs. isn't enough range. The current torque spec for wheel bolts is 118 ft. lbs. and a wrench that only goes 2 ft.lbs. above the needed value is too close to the end of range limit to be accurate at that value - you'd need one that goes to 150, 180, or 200 ft.lbs. to have good accuracy at 118 ft.lbs.
Old 06-11-2018, 01:41 PM
nougat
nougat's Avatar
Porsche raised the wheel bolt torque spec from 96 lbs to 118 lbs in 2012 (22 lb increase!). I'm guessing anything in that range is perfectly fine and your wheels won't fly off. I shoot for about 115 so I have +/- 3 lbs of in case my torque wrench is off. I bought a $40 torque wrench from Amazon and it came with a handwritten test report that showed accuracy was within tolerances.
Old 06-11-2018, 02:13 PM
linderpat
linderpat's Avatar
Received 2,250 Likes on 1,254 Posts
OK, a little OT, but why did Porsche raise that torques spec on wheel bolts? I've been using 98 ft lbs.
Old 06-11-2018, 02:52 PM
nwGTS
nwGTS's Avatar
torque was raised only for certain applications.. black wheel bolts are 118.. there's official Porsche language l posted in a thread a couple months ago. can't remember off top of my head.
Old 06-11-2018, 03:56 PM
Hi-Arc
Hi-Arc's Avatar
The most accurate torque wrenches are digital dynamic torque not static torque (breakaway) and beam style. Dynamic wrench has a velocity sensor and can measure torque being applied within a 2 degree fastener moving window. Typically within 1% accuracy. Great also for torque audit, yield and angle applications such as cylinder head bolts. Snap On definitely offers. The price has been coming down on this style wrench so it may be in many other MFGs.
Old 06-11-2018, 06:38 PM
GSXR750
GSXR750's Avatar
thanks for all the info, much appreciated
mike
Old 06-11-2018, 07:39 PM
Ben Z
Ben Z's Avatar
Counterpoint: Click-type torque wrenches are very convenient because you don't need to position it so you can read off a scale, but even the best of them goes out of calibration. If I were a pro I would definitely go with those and make sure they were calibrated on a regular basis. But for someone like myself who uses one occasionally, my Craftsman beam-type wrench I bought in the late 1960s has remained perfectly calibrated to this day. It is the only one I own or probably will ever own. I'm used to having to look at the scale, it doesn't bother me.
Old 06-11-2018, 07:52 PM
too tall
too tall's Avatar
Originally Posted by ColoradoMark
Split beam torque wrenches can be left at their settings without losing their accuracy.
https://www.amazon.com/Precision-Ins...2%3A1248909011
I have that split beam. That does the job.
Old 06-14-2018, 10:40 PM
GSXR750
GSXR750's Avatar
Thanks guys!!
tah dah
dog wanted to make sure it was as cool
Quick Reply: Torque wrench suggestions
