Rebuild - What else should be done?
As some of you may have seen, my 2007 C4S has been diagnosed with bore score. Thankfully it happened while still under Porsche warranty and they are starting the dismantling next week.
While the engine is out, I've asked them to see if the clutch needs doing (120,000kms) as hopefully it'd be a parts only cost seeing as the engine etc is out.
I began thinking is there anything I could do at this point to future proof the car?
Any thoughts folks?
Any thoughts folks?
get better sleeves than stock..ln nickies or darton steel liners..ims solution instead of stock bearing.
https://rover.ebay.com/rover/0/0/0?m...2F173318197603
if its a dealer doing rebuild they might not allow aftermarket stuff..
If a dealer is doing this they may or may not be amenable to upgrading it with aftermarket parts, which is a pity because unless they go to Nickies you end up with the same risk/probability of repeat bore scoring, and perhaps much sooner than another 120KKm. Regardless, as long as the engine is out I would do the clutch, clutch release fork, DM flywheel, AOS and all associated hoses/tubes, fuel injectors, coil packs and plug wires. If they are amenable to internal upgrades, check out rndengines.com list of what they equip their remanufactured crate engines with and ask for as much or all of that as possible. Personally I would go with and IMS Solution also.
Thanks for replies guys.
Only reason I'm getting the rebuild done in the dealer is that it's warranty work and free! Is the IMS still an issue in the 2007 3.8s? For some reason I thought they had sorted it out by then.
Thankfully the guy doing the rebuild has been a Porsche mechanic for 15 years and has done rebuilds previously.
https://rennlist.com/forums/997-foru...ml#post8924078
https://rennlist.com/forums/997-foru...ml#post9677220
IMS failure for 2006-2008 is very rare. I have asked several techs that I trusted with years of experience working at Porsche dealerships full time to give me the honest truth. I told them I am willing to pay to have the motor cracked open and a new ims solution installed. They told me not to worry and enjoy the car! This coming from one of the busiest dealerships here in Los Angeles, that over 15 years they saw maybe a couple of the earlier 2001-2005 with an engine failure due to ims. They told me that they had not seen any failures with model years 2006-2008, including the Cayman/boxster 3.4 engines.
with that said, by all means, if the engine is being cracked open make sure a fresh bearing is installed. If they are not willing to do the ims solution, then at least make sure they replace your old ims bearing with a brand new one that has that latest/greatest part #
I would +1 any of the suggestions that some of the engine rebuilders have listed as far as cylinder liners, pistons, rings etc.
These are all "while your in there" suggestions. Definitely freshen up all the clutch parts as someone listed above
-clutch
-dm flywheel
-throw out bearing
-clutch release fork
-pivot ball
-pilot bearing..
-new rear main seal
-clutch slave cylinder
-crankshaft position sensor
-AOS
-spark plugs
-coils
-injectors
-engine mounts
-water tank
-water pump
-coolant hoses
-new starter
-battery to starter cable (if not done already)
-Serpentine Belt
-transmission mount (inspect)
The list can go on and on, and those are just suggestions. Every part listed adds $$$$$
You will have to chose wisely, but I would seriously consider most of those parts be replaced if they have not been done yet on a car with 120k kilometers (75k miles)
-clutch
-dm flywheel
-throw out bearing
-pivot ball
-pilot bearing..
-new rear main seal
-AOS
-spark plugs
-coils
-injectors
-engine mounts
-water tank
-water pump
-coolant hoses
-new starter
-Serpentine Belt
Called down to them today to see what the progress is. They are starting the disassembly tomorrow. Requested the clutch change - parts only cost thankfully - €700.
I'll enquire about the warranty 'reset' on the engine, good call!
2007 - 11 year Porsche warranty?
Or aftermarket warranty?
If it is aftermarket? Then it is really like insurance.
Someone is paying for this job, through insurance.
You should therefore get normal Porsche warranty on the repair.
On my BMW it was two years. Don't know what Dublin is.-------------
The warranty period begins on the day of delivery to the customer or the date the vehicle was registered as a demo. The following coverage applies:
Warranty can be obtained from any Porsche dealership across the world.
*Applies for vehicles purchased and registered in the USA and Canada. (If bought outside the USA and Canada, warranty is 2 years / unlimited kilometres).
https://pfaffporsche.com/national/44...y-periods.html
Warranty Periods
The warranty period begins on the day of delivery to the customer or the date the vehicle was registered as a demo. The following coverage applies:- 4 years / 80,000 kms for all new vehicles whichever occurs first*;
- 2 years warranty for genuine Porsche parts, remanufactured parts and accessories, which are used or sold outside of warranty work. The warranty period for Porsche parts which are used in connection with warranty work ends contemporaneously with the warranty period for the purchased item which has become defective;
- 8 years / 130 000 kms Emission design and performance warranty
- 10-year corrosion warranty against perforation in the bodyshell (please refer to the conditions in the Owner's Manual and Warranty and Maintenance handbook)
-clutch
-dm flywheel
-throw out bearing
-pivot ball
-pilot bearing..
-new rear main seal
-AOS
-spark plugs
-coils
-injectors
-engine mounts
-water tank
-water pump
-coolant hoses
-new starter
-Serpentine Belt
-clutch
-dm flywheel
-throw out bearing
-pivot ball
-pilot bearing..
-new rear main seal
-AOS
-spark plugs
-coils
-injectors
-engine mounts
-water tank
-water pump
-coolant hoses
-new starter
-Serpentine Belt
The current warranty that this work is being done under is the 2 year warranty I got with the Porsche Approved sale from the P Dealer. Thank jayzus that exists....
Option to extend (at a cost obviously!) By another 2 years when this expires subject to inspection / mileage etc.
When do you have to buy this extended? Now? or before the expiration of the rebuild 2 years?
What is the cost now, vs 729 days from now? Is it transferable to a new owner. Is there cash back value if not used?
Had the rebuild not occurred, I would have had to renew before end of current warranty.
It is transferable to a new owner, but only on a private sale.
If I was to sell to a dealer, I can cash in the remainder of the warranty.
