Heel and Toe - OEM Pedals
So is it me or is it really hard with stock pedals to perform heel and toe. Starting to hit entry harder and noticing downshifts are unsettling the chassis a tad. I can see where I need to learn how to heel and toe soon.
Anyone doing this successfuly on the stock pedals or do I need something like the rennline pedal set.
For me the brake is way too high. If I am hard breaking I can sometime blip 500rpm but that's not enough and doesn't work at all with lower braking force.
I don't have any problem heel and toe-ing in mine, I believe that is because I'm short and my feet are really vertical. This allows me to be at the very top of the gas pedal when blipping.
That said, it doesn't matter one bit that I don't have a problem and you do. In racing, that's the first thing you have to do as a good driver. Make yourself comfortable. Look around in their cars and you will find the pedal configs of some of the fastest drivers are ridiculous.
Buy new pedals, bend yours, whatever, put them how you like them. Don't worry about resale to a new owner because you can inform them that they should do the same.
If I rotate my heel far enough towards the gas pedal before rolling my foot, then it is not an issue. I have been considering the Rennline throttle pedal with the side extensions so I don't need to rotate, but I have read that sometimes people accidentally hit the extensions under heavy braking.
Brake pedal bites more and earlier with sports cars, and the brake has to be further down to get a good purchase of the accelerator. In other words, you have to brake harder in order to have good throttle control. So naturally, you have to be driving harder in order to heel and toe more comfortably.
In contrast, I had a Fiat 500 abarth, where the brake and throttle sat at the same levels at rest. I could heel toe comfortably in traffic, but in the canyons the brake pedal was way too far in.
brake pedal in our cars is oriented such that heel/toe is perfect at threshold braking like on track... not when you're at 50% like on the street.
to counter, get a throttle spacer or adjustable pedal set like from rennline.
this has been discussed ad nauseum in a couple other threads here too if you're looking for more info.
2009 C2S 125K miles
https://rennlist.com/forums/997-foru...gas-pedal.html
The stock config is not good.... see my thread above where I installed a Rennline pedal and no I heel toe with mad abandon.
Peace
Bruce in Philly
Peace
Bruce in Philly
^^^ That's one of the better ones here.
Plus, if it pissess off Bruce, it'll likely pisses off everyone. He has a high tolerance.
Oddly enough, there was a pedal extension on my throttle when I bought the car. I didn't like it. Went back to normal so I could heel toe like normal (I roll my foot side to side, not "true" heel-toeing).
I admit, you have to be pretty deliberate with your blipping to get the rev's up, but isn't that the point of H-Ting? If you're not driving hard enough to need to brake that hard... chances are a simple regular blip of the throttle to rev match should suffice. I learned to H-T & double-clutch back in my Comanche days; gutless 2.5 and a 4spd with tired syncros.
Or maybe I just drive like a total a$$hole on the street.
(I do.)
Cheers
(I do.)
Cheers
Good stuff.. thanks for the info.
So is everyone just running the pedals and maybe the lifter kit and extensions?
What's the point of the full assembly they sell. Mentions weak stock setup.. anyone had issues with stock pedal assembly breaking?
Brake pedal height is adjustable--see post #8 here: https://rennlist.com/forums/997-foru...justments.html
I heel/toe on every gear change to limit the wear on the clutch. You may think....bah, but on the other car we are currently on 125k miles on the original clutch and no signs of throwing the towel in.
I don't have any issues with the factory set up of the pedals. In fact I was on a blast with some fellas and they were convinced by my exhaust note that I had a PDK gearbox.
I'd say save your money and work on your technique OP
Only time a clutch wears is when its going in, coming out and slipping. If you aint slippin it, it'll go forever. I've driven manual cars (and race cars) for 35 years and have never replaced a clutch due to wear. Knock on wood...
