Porsche admin print buildsheet link is no longer working
They're only banning us tire kickers ! I guess if I put in my Christphorus subscriber ID I can trick the system.
BTW - does Porsche still start sending these to you for free after you've registered a P ? That's the way it used to be.
[QUOTE=Meursault88;14970031]They're only banning us tire kickers ! I guess if I put in my Christphorus subscriber ID I can trick the system.
You got in? What exactly did you do?
It's working for me, using google Chrome
Basic Sponsor
Ditto - odd.
High Temp Caliper Rebuild Kits; Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
It's back online, I'm able to generate build sheets via porschevin.com ... technical hiccup on their end I'm guessing?
Guys, a posted in another thread found the issue and how to fix it. In the beginning of the link, there is https://admin.... this is for Secure connection. Remove the "S" after "http" and it will work just fine. So your link should be like this http://admin.porschedealer.com/repor...print.php?vin=
Happy bout it!
porschevin.com working for me now
the actual Porsche pages are still blank but at least I can use something !
Guess next time should be more chill...
