to much oil resudue in intake tubes, possible vacuum leak?
I changed out my Knock Sensors and the one on the right side between oil cooler and AOS, the AOS needed to be moved to get to the Sensor so since I there I replaced it with a new one, reason why was i was/am getting a little more oil than normal residual film in the intakes and intake tubes.
My question is: the excess oil in the tubes due to a crank case vacuum leak? I can't see any other way that that oil residue can make its way into the intakes. Any info on this would be greatly appreciated
Hectoy.
Hectoy.
AOS could also be failing.
