Hella-Buggin'
close
- Join DateNov 2009
- LocationPNW
Liked:535 Times in 261 Posts
Quote:
And you're absolutely right; I'm sporting 235/265 potenza S-04; the rubber gives up before the brakes do. I didn't consider the OP wants to go R compound. Are factory S calipers even up for that?
Right on. Gotta get that stress relief anyway you can. After a weekend away from the wife & kids, the last thing I'm going to get is a few extra hours alone with the 911.Originally Posted by Appraiser
After every weekend (2 events). Zen maintenance process. I clean out the flak/debris, wash the car and wheels, change oil, change brake fluid and verify everything is still clean/tight. The extra 30 minutes and $38 is cheap peace of mind and a nice break in the garage.And you're absolutely right; I'm sporting 235/265 potenza S-04; the rubber gives up before the brakes do. I didn't consider the OP wants to go R compound. Are factory S calipers even up for that?
