Tooki & NAV-TV iPod connector - Lightning compatible??
Anyone that has a Tooki & NAV-TV iPod connection in their car ever tried a 30-pin to lighting adapter, Apple of aftermarket? Successful?
My car came with it installed, but the Apple 30-pin connector is broken and also very dated ...
Looks like the cable has an RJ-45 connector on the other end, so I'm wondering if I can repair the cable and covert it to a lightning plug while I'm at it. But before I go down that path, I'm wondering if it would even work and correcting interface with the PCM.
For reference, I'm referring to the white cable on the left side of the image below.
https://navtv.com/products/NTV-KIT14...che-combo.html
Not to be a nudge but my recommendation would be to ditch it and buy the new LaPower bluetooth audio and handsfree calling unit. Its like $140 and integrates perfectly with the PCM 2.1.
If you search for the post called LaPower Bluetooth you will see where to purchase and install instructions.
Even if you get the same 30 pin to RJ45, you'll need an adapter to convert to lightning. So might as well try a direct route.
I think you can get a generic 'Lightning Ethernet Cable' to begin with (around $20 online, maybe cheaper if you search).
If that doesn't work, you still can try TheBruce's suggestion.
Does the LaPower system also have charging functionality? I would mainly use it for bluetooth, how's the call quality? The Tooki is quite good.
Thanks, that's also an option. I was inclined to keep the current system without investing too much more, but I guess now that I have everything ripped apart for painting, now is the time to think about it. Does the LaPower system also have charging functionality? I would mainly use it for bluetooth, how's the call quality? The Tooki is quite good.
Call quality is very good. I just installed the mic under the steering wheel and everyone says it sounds fine. When you get in the car the bluetooth automatically connects and starts playing where you left off. It offers all the features of the Dension units at 1/4 of the price. Its the best ROI mod I have done to my car so far. I hated the PCM 2.1 until I installed this. Now it has all the conveniences of the PCM 3 with a little vintage charm.
The only thing I learned was if you tap the power socket in the passenger footwell you need to make sure you lock your doors overnight. That circuit stays powered up until the doors are locked so anything running off that will wear the battery down. If you tap the PCM power cable that will eliminate this minor issue. I found out the hard way...
Good luck.
30-pin-to-lightning runs what, $30? And you won't be able to charge your iphone while you drive and still won't have BT. As long as you have the dash apart anyway, I would definitely go for something more modern. I've got a Tranzit BLU-HF, I did read a thread about the La Power unit which has on-screen integration (but somewhat limited functionality compared to a touchscreen) although I recall some people had issues setting it up, and of course there's always the option of replacing the head unit.
When I was researching options to add BT I considered the Tooki first, as NAV-TV's national HQ is across the street from my office. They said it would only do A2DP music streaming through some, not all of the speakers. I believe it was just the front ones, but it's been a long time. Perhaps later units overcame that shortcoming. Have you tried streaming and does it come out all the speakers?
I should really find some instructions on what features / functionality I actually have haha!
