Borrower a Durametric?
Hi,
I'm in NYC/NJ/CT and want to try to clear a code. Does anyone in my area have one to borrowed (or rent)? I repainted a bumper and now I’m getting the System Failure message.
Any other suggestions to clear are appreciated.
Are you talking about the system failure light when you disconnect the battery? If you are all you have to do is drive the car forward then backwards and turn the wheel several times to the right and left and it clears itself.
This likely relates to some static issue when body shop was washing car. I’ve been doing my homework. I’m not sure if it’s front control unit or rear.
