Tail lights protection film
Finally bit the bullet and bought a new pair of tail lights for my 997.2. those things are damn expensive. Anyways, mine developed mini cracks inside the lens that seem to rediate from near the engine hood towards the sides. Happened for both lights... Now before installing the new lights I wanted to get ideas how to protect them from having the same defect again... The new lights have updated part numbers which hopefully have better quality plastics... Nevertheless I would like to put clear protection film on them... Do these things actually provide any protection? I understand its use for headlights but for taillights????
here's a link to my previous post so some would see the condition of the tails..https://rennlist.com/forums/997-foru...scratches.html
Say Yes to PPF
Hope this info helps. Let us know if you have any other questions.
XPEL Inc.
Support@XPEL.com Phone: (210) 678-3700
XPEL.com "Like" us on Facebook Follow us on Instagram
XPEL Inc.
Maybe I will just think it prevents uv attack, which seldom happens for taillights, but... I guess it won't hurt to put... I'm just concerned at what caused the crazing before and would want to be more proactive to prevent it from happening again if at all possible. Though I'm highly suspicious it's a material problem as I've seen it on panameras and as some said here cayennes
I have the same problem on my 2010. The left side has now cracked across the lens and is forcing my hand. Mine is a daily driver so UV damage is my guess.
Were you able to locate parts for less than $1K per set? I will definitely protect the new ones with UV film. Something is wrong with the material spec.
