XM/Sirius on a PCM2.1
I recently read that you can toggle the PCM 2.1 to XM radio simply by simultaneously pushing the MAIN and TRIP buttons on the unit.
What is the procedure to get an account activated, if you can toggle over to XM/Serius? There appears to be some issues in getting service established in the little bit of research I've done.
Sirius/XM was not available from the factory for the 997.1. However, it was an option for the Cayenne, which also used PCM 2.1. Therefore, I bought a Cayenne Sirius/XM receiver and installed it with my existing 997.1 PCM 2.1. It works well provided you place your antenna in a good spot -- most of the posts about this suggest a spot that works horribly. As far as switching to XM, all I do is toggle my AM/FM button. You get the following sequence: AM - FM - XM, and repeat. It shows up on the screen list like AM and FM do.
Once I had things this far, all I did was call up Sirius/XM, and they walked me through setting up an account and activating my receiver.
I think it takes the place of the CD changer in the MOST fiber loop. I added the Nav TV XM tuner to my 997.1 when I had it. That MOST connector is a real PIA in terms of getting it assembled. If you have never done any car stereo or electronic installs don’t try it yourself
