Electric Power Washer/Foam Lance for Ceramic Coat and Xpel?
Nathan for the win as always. I probably will not be putting a mitt to the car since the truck will see rainy work days, and the motorcycles see most sunny days. From what I hear ceramic coatings don't ever really require a mitt as long as you use the appropriate nozzle. Thanks for that link, good info.
Check your FB messenger for some teaser pictures of the Turbo Nate
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_0094_a057dce3bc4720beb4e9c1f986ce9363f938134d.jpg)
Adams car shampoo
power wash 15-25 degree nozzle to get road grime off
foam and then rise with 25 degree or just open ended hose
two bucket wash I really think the biggest difference maker is this step with the proper wash mitt or edge less microfiber...cheap microfiber scratches xpell or clear coat like crazy.
finish with open ended hose and watch the water just cascade off. Easy drying with blower or Adams drying towel. My 997 was paint corrected and I have followed this since and zero scratches or any signs of swirling.
Good luck!
Try watching the Junkman series on You Tube.
Excellent stuff.
Yves
Excellent stuff.
Yves
I ended up with the same pressure washer with the MATCC foam cannon (some of the cannons dont have the correct quick disconnect for the SunJoe pressure washers). I have just been using the meguiars gold class car wash and it works well. I usually use the 40 degree nozzle after I got the car ceramic coated (the dirt really just runs off). For a quick clean, I do a pre-spray, foam cannon, final rinse with the pressure washer, and then use an electric blower to finish things off.
Ceramic coating makes everything easier. I wish I would have done it sooner. If you use your favorite wheel cleaner and the 25 degree nozzle on your wheels in addition to the foam cannon, you can be super lazy and still end up with a clean car. Best of both worlds![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Gents,
Buying a car that is getting a fresh ceramic coating and xpel front clip clear bra.
What kind of electric power washer/foam lance/chemical do you all recommend?
So far I have gotten the Sun Joe SPX3001 for washer and the MTM Foam Cannon. Not sure what chemical to use, should I just ask the company doing the treatment?
I will be using the for my upcoming 997TT, my truck, and all the motorcycles(not the matte black panigale) as well.
