Brake wear sensor electrical diagram
Hi, does anyone have or know where I could get an electrical layout of the brake sensor circuit as I have the fault up all of the time yet all pads and sensors are new,,,??? Regards mark
Check your sensors. I don't know about a diagram, but the sensor is just a closed loop circuit. You can short it with a paperclip and defeat it if you want.
If you're getting an error, it just means something isn't plugged in or a sensor is worn down and wasn't replaced.
I bypassed mine. I bought a set of sensors, soldered the wires together to close the circuit and used high temp shrink wrapping to protect it.
