Cabriolet help
I don't have a 911 Cab however on my Boxster on the inside of the top frame about where your head is in comparison to the top of the side window there is a joint. The joint has a hinged cap on it that opens as the joint bends. Mine started making a pop sound as the hinge stuck for a second on the opening frame. I just put a little lubrication on it.
Not sure this will help. I had to watch and listening until I saw it. If you need a picture I can take one.
thanks, I think I found the issues, when near the closing of the top, the top is getting caught on the latch. not sure how to fix that?
