TPM Partial Monitoring
TPMS Partial Monitoring
I had this message come up several times on the weekend. Has to do with the front left tire. Is it the sensor going or the monitoring unit? 2011 car original sensors I believe
Error code 8021. 8003. 8004
I found it.....when there is a faulty wheel transmitter...... guess I'm buying 4 new ones as I'm sure the others are not far behind
http://www.porscheownersmanuals.com/...ial-monitoring
6 or 7 years seems to be the normal life for these things, so yes, it was time.
Once mine go past 5 years, even if they're still working, I will replace them the next time I buy new tires. It is Murphy's law that if you get a new set of tires, at least one of your TPM units will go south within a few weeks.
