Adding some upgrades to my '04 Turbo!
Thanks to a lot of reading on Rennlist, and a track event that I felt I could have performed a LOT better in, I decided to put together some upgrades for this 2004 Turbo that I LOVE.
This is what the car has so far:
GIAC Tune
NHP Headers and Exhaust
Lowering Springs (on stock shocks)
SACHES 750hp+ rated clutch
Short Shifter
19" Champion Motorsport RS98 Monolite Forged Wheels
These new parts are being added:
(2) Champion Motorsport Forge Racing Diverter Valves (Yellow springs)
Eibach Sway Bars + Bushings
Bilstein B8 SPORT Shocks/ Struts (Yellow)
Full Suspension POWERFLEX bushings
Torque Solutions Transmission Mount, Engine Mount and Subframe Bushings
Agency Power Dual Flow Carbon Fiber Intake
IPD 68mm Intake Plenum
(2) Larger Capacity Intercoolers
All Intake Piping (w/ "F" Pipe) AND Cooling System Piping
Stainless Steel Braided Brake Lines
AASCO 13# Light Weight Flywheel
While I do this I am switching out the standard brake fluid with a type that has a higher boiling point so it can handle racing.
I have it at the shop now but will report back once everything is installed!!
GIAC Tune
Short Shifter
What kind of differential is on the front?
Get rid of it and get the LSD and remove the PSM when you learn the car and you will be surprised the cars this thing will catch in corners let alone straights.
The front diff is worthless - it is thrown into the turbos so the general public doesn't kill themselves. The AWD is awful and in turn is a negative for the track, excessive understeer and lack of ability to put instant power down out of corners.
I'm on Guard's website and they have 3 models
Applications
LSD Application
GT2 Pro GT2/GT3/G50/996/Turbo/968/Boxster S ’00-’04
GT3 Club GT2/GT3/G50/996/Turbo/968/Boxster S ’00-’04
GT1 Pro+ GT2/GT3/G50/996/Turbo/968/Boxster S ’00-’04
no you remove the front drive shaft and diff entirly and throw it away or sell it... the rear is an open diff it will need to be replaced with the guards lsd. email matt there are 2 versions based on how much horsepower you end up having really is the difference
Technically that would convert the car to a GT2?
returen the a/p dual intake its junk. no need for the ipd plenum either in the current engine setup. take that money and buy some track wheels in 18" and track tires. that will help more than most of the mods your adding. 18" for go 19" for show!
https://www.tirerack.com/tires/tires...N+Neova+AD08+R
Everyone bashes the AWD but it does work. It's a mechanically system that isn't that bad. I would like to convert my car to RWD but I won't say the AWD doesn't work.
on the street I agree - on the track it is a hinderence for a proficient driver...a rookie may like it however since it masks a lot of errors.
