996 Turbo Forum 1999-2005
5w50M1 at Napa for $5.80 qt
Old 03-13-2017, 01:34 AM
iotapi322
iotapi322's Avatar
Default 5w50M1 at Napa for $5.80 qt
Saw this over on 6SO and couldn't believe it.
Just online order ahead from your Napa and pick it up.
https://www.napaonline.com/en/p/MOR122075
That is much cheaper than the $52 deal I normally get from Amazon.
Old 03-13-2017, 03:39 AM
911mhawk
911mhawk's Avatar
Thanks, I have enough oil to last me a long time now
Old 03-13-2017, 10:13 AM
splitime
splitime's Avatar
And next two oil changes now covered. Thanks
Old 03-13-2017, 10:16 AM
Vendetta NY
Vendetta NY's Avatar
Fantastic, thank you for sharing.
-V
Old 03-13-2017, 10:21 AM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
Mobil has the $12 rabate going too, so the net price is $3.80.
Old 03-13-2017, 10:26 AM
LexVan
LexVan's Avatar
Rebate here:
https://mobiloil.com/en/promotion/mo...nd-mobil-super
Old 03-13-2017, 10:35 AM
gophaster
gophaster's Avatar
Nice, they do the rebate quite often. Check comes back pretty quick too. Guess I'm buying more oil. Thanks
Originally Posted by LexVan
Old 03-13-2017, 10:38 AM
LexVan
LexVan's Avatar
Over the past 2-3 years, I've seen Napa run this sale every 3-4 months. The Mobil rebate, I've seen offered once per year. It's great when you can double-dip.
Old 03-13-2017, 10:42 AM
ANJ-911
ANJ-911's Avatar
Thanks for sharing this, been wanting to use 5w50 for my next oil change - Are you guys in the more northerly states running straight 5w50 or doing a 50/50 mix with 0w40? I'm in Maine, only drive the non-winter months (usually April-November), and don't run the car on the track. The car may see the occasional below 32°F startup though.
Old 03-13-2017, 10:50 AM
LexVan
LexVan's Avatar
Same as you......car only used March-October. I run straight 100% 5W50. See my Blackstone reports in the 991 Forum.
Old 03-13-2017, 11:30 AM
"02996ttx50
"02996ttx50's Avatar
i'm also a 5/50 M1 convert. changed it yesterday and also got it on amazon for 6 per qt in boxes of six. the price went up a day later to 52 a case! so i saved 4 bucks lol
the car is *happier* ( and quieter ) running the heavier oil, particularly in summer out here when it's regularly over 100 degrees outside.
Old 03-13-2017, 12:42 PM
bugeyemilo
bugeyemilo's Avatar
well,
garaged occasional spirited driver,
car never sees 100 degrees nor does it see below 32 ish..
so the question is: stick with 0w-40 or move up to the 5w-50..
both are on sale currently.
Old 03-13-2017, 12:44 PM
"02996ttx50
i'd split the difference lol..and go with 5/40!
LexVan
LexVan's Avatar
This.
Old 03-13-2017, 01:19 PM
911mhawk
911mhawk's Avatar
Thanks again too, $96 back on 40 quarts makes it $135.60 total.
After reading Mobil site it looks like you'd better buy it 10 quarts at a time to get the most out of the rebate details.
Add $8 a filter and that's $41.90 for a 10 quart oil change leaving some for topping up.
Quick Reply: 5w50M1 at Napa for $5.80 qt
