996TT vs. 997.1TT
996TT vs. 997.1TT
Can someone enlighten me on the what the major differences are between 996 and 2007-2008 997? Obviously the 997 has a revised interior and no fried eggs but what about the engine, basically the same as 996?
Thx
Thx
both have the funky coolant lines, but only the 997.1 has issues with the cams...
The one interesting thing with the 997.1 TT is that its electronically controlled suspension can be modified from reactive to proactive via a software upgrade and the fitting of an aftermarket control module. Proactive suspension is the bomb.
And the 997 has the better AWD system. No more viscous coupling. The transfer case (?) is a multi-plate wet clutch. The amount of engagement is controlled by the DME.
Under a hard launch the 997 AWD system can actually transfer considerable torque to the front tires.
I have no idea what if any restrictions there are on the 997 Turbo front and rear wheel/tire diameter ratios.
https://rennlist.com/forums/997-turbo-forum/847001-spun-camshaft.html
/\ That's the thread that kind of spooked me out. OP had $7k fix via Fidelity warranty....
I believe the 997 AWD cars are free of the tire height restrictions we face and can run a taller back tire. I'm sure there are some recommended sizes, but since all the 997s seem to run 19s they have a lot more choices.
The 997 can use a wider range of tire sizes but there is limit, mostly due to the PSM programming.
996T vs 997T
The 997 turbos are water-cooled. The 996 Turbo turbos are just oil (and "air" -- exhaust gas "air") cooled. Thus the guideline in the 996 Turbo owner manual to let the engine idle 2 minutes before shutting off the engine to give the turbos time to cool down. T10Chris mentioned the VNT aspect. Very cool technology. My 2002 VW Golf TDi had this feature and the level of boost control was amazing.
The 996T transfers considerable torque forwards too, but with what looks to be about 0.2s (car hot) to 0.5s (car cold) delay. So the 997.1 AWD system helps launch them a bit faster.
I read somewhere that the improved efficiency of the 997.1 AWD system is also it's downside, as it is said to be more intrusive (less progressive and predictable on the limit) during very spirited driving on road or track. For the 997.2 generation, Porsche reportedly retuned the electronic contol unit to operate the electronic AWD clutches in such a way as to more closely replicate the behavior of the 996T's viscous unit. Take from that what you will.
As for other differences, I think steering became variable ratio on moving to 997.1 and some feel was lost (as seems to happen pretty much every generation). Thankfully (Porsche already lost it on the Cayenne back in 2003) the 997 still has a proper handbrake though.
As far as I can tell the only issue with 9A1 engines, and I stress it is a very rare issue, is with cylinder scoring if the engine is repeatedly driven very hard without properly being warmed up.
Rrussval (02-03-2020)
