996 Turbo Forum 1999-2005
Proper Oil Level??
Old Oct 24, 2003 | 01:39 PM
Fred R. C4S's Avatar
Fred R. C4S
Question Proper Oil Level??
I just had the oil changed for the first time in my 03 TT. By adding 9 quarts, the level on the gage (when warmed up and on a level surface) is halfway between the max and min marks. I asked the mechanic if this was correct and he pointed out that it was the same as with my 964 or 993. The optimum amount was halfway between the marks. Fill to the max mark, and you will burn more oil, particularly at start-up.
I followed this approach with both of my previous 911's, but am curious as to what oil level others run and what their experience has been.
Thanks,
Old Oct 25, 2003 | 08:48 AM
ypshan's Avatar
ypshan
There seems to be some truth to that based on my observation of the last 3,000 miles or so. I will have to watch it a bit longer to know for sure.
Old Oct 25, 2003 | 02:10 PM
FixedWing's Avatar
FixedWing
Your mechanic would normally be correct however the Turbo has a dry sump system.
Stephen
Old Oct 25, 2003 | 06:19 PM
Chris Y.'s Avatar
Chris Y.
I run mine right at the middle and it still smokes at start up....
Chad, what is fall less oil???
Old Oct 25, 2003 | 06:39 PM
Chris Y.'s Avatar
Chris Y.
No problems Chad... I thought you had some magic potion you haven't told us about
Before I used to top it off...but now I noticed my car has been using far less oil also.
Old Oct 25, 2003 | 10:28 PM
JMT's Avatar
JMT
On a dry sump system, I do not belive oil level, has anything to do with oil consumption or having smoke on start-up. The oil is in continuous circulation.
Old Oct 25, 2003 | 10:41 PM
Fred R. C4S
Gents,
My 10 experience with the 964 and 993 did indeed indicate that if the oil was filled to the midpoint on the dipstick the car burned oil at a slower rate. I am just curious if this is also true of the newer 996TT engines.
And yes, I'm fully aware that the engine has a dry sump.
Regards,
Old Oct 26, 2003 | 07:53 AM
FixedWing's Avatar
FixedWing
My car tends to use oil faster as the level gets lower!
But this always seems to happen when I'm in some distant land, have run out of the Mobil One I brought with me and finding more is going to be next to impossible.
Seriously though, I don't think the measure is quite linear.
As for smoking, etc. ... the level in the engine will always be the same. There are pumps which scavenge the oil back to the header tank. Those scavenging pumps will pick up whatever oil they find. The level of the oil is the level in the header tank and I'm not aware of any direct way that this oil can get to the exhaust.
Stephen
Old Oct 26, 2003 | 12:27 PM
JMT's Avatar
JMT
My experience has been identical to Stephen's (FixedWing) except all of my added oil has been Mobil 1, 0-w40.
As for smoking, etc. ... the level in the engine will always be the same. There are pumps which scavenge the oil back to the header tank. Those scavenging pumps will pick up whatever oil they find. The level of the oil is the level in the header tank and I'm not aware of any direct way that this oil can get to the exhaust."
Stephen
Old Oct 26, 2003 | 05:32 PM
FixedWing's Avatar
FixedWing
Originally posted by cjv
Stephen, your turbo's are cooled by your engine oil. There is also a small oil tank near each turbo. If these tanks do not drain fast enough or to much oil is feed, then oil is induced through the hot side turbo bearing. For some reason Porsche uses a much smaller tank on the passanger side turbo than they do on the drivers side turbo.
So you are saying that the level in the header tank somehow affects the speed with which the oil in the turbo will be returned to the header tank and that too much oil here will cause more oil to be sucked past the bearing into the hot side of the turbo and then out of the exhaust as oil smoke?
Ok, well, I have no evidence one way or the other on this.
Stephen
Old Oct 26, 2003 | 10:32 PM
Joe West's Avatar
Joe West
6th Gear
How odd that others would be using 9.5 quarts to get midway between the max and min marks when I use 8.5 quarts to get to the max full mark.
Wonder what the difference is.
I'm at about 6k miles now, and burning about a quarter of a quart every 2k or so miles.
I've always run the oil at the max fill mark... as it was when I received it from the dealership.
Joe West
Old Oct 27, 2003 | 01:26 AM
drafting's Avatar
drafting
[i]
Joe ---
I take it that you've already changed your oil out? Your consumption rate is the lowest that I've heard of for a new P-car, you've got one tight engine! How are you enjoying that new TT?
I went through 3 liters in the first 3800 km, but don't know if that has started to taper off at all. It was some fun driving, but nothing like track usage.
Jeff
Old Oct 27, 2003 | 03:17 AM
FixedWing's Avatar
FixedWing
Originally posted by Joe West
How odd that others would be using 9.5 quarts to get midway between the max and min marks when I use 8.5 quarts to get to the max full mark. Wonder what the difference is.
Did you also drain the turbos?
Eight litres does it for me actually.
Stephen
Old Oct 27, 2003 | 03:30 AM
FixedWing's Avatar
FixedWing
I may stand corrected, but I believe the speed of oil return is governed by gravity. That is why these lines are sloped. I can tell you this. When I installed larger turbo's I not only had smoke but also a small leak on my passenger side turbo. The problem was the oil tank was too small for the turbo. The tank was enlarged and the problem disappeared. If you look at these tanks you will see the passanger side one is half the size of the driver side one. I don't have an explanation for this.
I really don't have the background to discuss this. However, it would surprise me if the turbos were gravity return given that the turbo tanks seem to be about the lowest things on the car. I think that they are lower than the oil level in the crank case and they are certainly lower than the oil level in the header tank.
Why gravity return? Everything else in the oil system is mechanically driven.
Stephen
Old Oct 27, 2003 | 07:03 AM
cobra06's Avatar
cobra06
The turbos have an engine driven extraction pump on the intermediate shaft.
