Psm On When Braking
Psm On When Braking
I understand that when PSM is put manually off , when braking, it will get on again . In my two last cars ( both with PSM), I could ( and can ) not see any sign that this is happening. Also, I donīt know for how long is PSM back ON again: only when braking ? Will it be off again until put back manually on ?
If you use the console switch to turn PSM "off" it's _enabled_ under braking. In this mode PSM won't try to help you if the car gets out of shape and you're not on the brakes but if you're on the brakes and it thinks it should do something it will. Turning the car off resets PSM back to the always on mode.
Re: Psm On When Braking
Originally posted by boqueron
[...]Also, I donīt know for how long is PSM back ON again: only when braking ? Will it be off again until put back manually on ?
Greetings,
--Pierre
