How much oil are you burning?
The car just turned over 5500 and I am adding my 4th quart of oil.. looks like 1500 per quart... 2003 996tt
Is this in line what others are burning?
Try to find the thread on the driving technique to help you seat the rings. It goes thru a regimen of driving up to higher rpm's, and backing off in-gear (to create negative cylinder pressures as I recall). It goes in a progressive cycle upward thru several gears, with several cycles in each gear. I believe it was posted by one of the moderators. AS
Keeper of the Truth
I used 3 liters (about 3 quarts) in the first 3800 km (about 2400 miles). I don't know if consumption has yet leveled out. I was attempting to follow the aforementioned rev up/down, under load and in gear regimen during break-in (as well as not cruising at a consistent engine speed), so it'll be interesting to see if that paid off w/ a nice, snug ring/cylinder fit. Only intermittently saw the "traditional" poof of blue smoke upon startup.
Jeff
Jeff
My 01's about half that rate but it
took awhile to get there. My oil consumption was about where yours is now from the time the car had 3,000 miles until I got over 10,000 miles. Mine now has 24,000 and it burns about a half a quart every 1500-2000 which includes DE's. So with more miles you may see a further decline.
I'd say yours is "normal" but I know of others who's 02-03 burn almost no oil. There is a pretty wide variance car to car.
