Someone educate me brake fluid change frequency.
#31
You will not be able to judge the negative long term effect of the corrosion of internal brake components due to the accumulation of water in the brake fluid just yet. This will happen in another 10 years or so when the cylinders begin to fail, or the brake lines begin to rust through. Dan
