996 Turbo Forum 1999-2005
DIY: Modding front radiator brackets for big tires
Old 03-14-2016, 05:45 PM
powdrhound
powdrhound's Avatar
Received 1,723 Likes on 1,003 Posts
Default DIY: Modding front radiator brackets for big tires
It is no mystery that the problem with running wider and taller tires on the 996tt/GT2 is the interference as you turn the wheel between the front tire and front fender liner "bubble" which is there due to the radiator bracket. Running aggressive wheel offsets only makes the situation worse because the more aggressive the offset, the larger turning radius the wheel will have. Since this has come up recently in numerous threads, I figured I'd post up relatively simply DIY mod to create more clearance for running larger wheels and tires.
We modded the brackets in this fashion to make it very "OEM" and virtually impossible to tell there is any modding involved. There is no partial cutting and bending of the bracket. If you like doing things as close to OEM as possible, this may be the mod for you. First, you will need to remove both radiator brackets which is very simple btw. You just remove 1 nut, 2 bolts, unclip 3 clips that retain the radiator locating pins and the whole bracket comes off. The radiator assembly will remain in place held by the hoses. You can support the radiator with something while the bracket is removed but it's not necessary.
Once the bracket is out, you simply cut out the part of the bracket that takes up a majority of the room in the fender liner "bubble". This, in and of itself, will give you about 5/8" to 3/4" additional clearance. You can then "slot" the 3 holes in the radiator brackets a little bit to allow you to push the whole radiator/bracket assembly forward. We gained another 1/8" to 1/4" of room by doing that. I used a simple Harbor Freight 4" metal grinder and smoothed all the edges with a carbide bit. Clamp the bracket in a vice while you work on it. Once all is smooth, you can lightly sand the bracket and spray it with matte black paint for that "OEM" finish. For those that are questioning the integrity of the brackets after this mod, have no fear. The brackets are super beefy made of steel and you could practically hang and elephant from them. Even when trimmed they are super sturdy and more than enough to supper the radiators which only weigh about 10lbs including the fan.
The final step is to heat and flatten the fender liner "bubble" to make sure the liner is nice and snug up against the radiator bracket. Using GT2 fender liners makes this relatively easy as they are made out of a thinner material that is rather easy to mold. Besides this, the GT2 liners other benefit is that they vent radiator air to the back of the wheel (as opposed to out ahead of the wheel on the TT) where it can be diverted to the front brakes via brake ducts.
While you have the radiator bracket out, you can also slot the mounting holes in the bracket which will mover the whole radiator assembly forward 1/2" or so giving you even more room ahead of the tire. This is easy to do with a Dremel and a metal grinding tip.
I will also note that the way to maximize room for big/wide tires in the front is to run a wheel offset that will minimize the wheel turning radius. A GT2 runs a rather aggressive ET40 offset but it only uses a rather skinny 235 tire. To run wide wheel/tire combos, you will need to choose an offset that puts the front wheel as snug as you can up against the front strut. Running smaller diameter 2.25"/60mm coil over springs with a wheel offset of ET43-44 on a 9.5" or ET36-38 on a 10" wheel is the key. This will effectively minimize the turning radius of the wheel. You can then shim the LCA to the max track that you can get for the wheel to clear the fenders. The exact amount will depend on the camber you are running. The more camber, the more shims and wider track you can run.
Here is a picture of the stock radiator brackets from behind and the side. I have marked out the "interference" area to be cut away with a silver majic marker.
[url=https://flic.kr/p/ESxCGx]
[url=https://flic.kr/p/E4mzfZ]
Here is a picture of the stock radiator brackets after the area in question above has been cut away and the bracket sprayed flat black.
[url=https://flic.kr/p/E4kRJx]
[url=https://flic.kr/p/E41vLW]
Here is a picture side by side of the stock (on the left) and the modded bracket (on the right). The difference is obvious. The brackets in the picture are flipped, the right side bracket is on the right and the left side bracket are on the right.
[url=https://flic.kr/p/E41vXY]
It goes without saying, perform all modding at your own risk...
Ratchet1025 (06-28-2022)
Old 03-14-2016, 06:05 PM
Scott.
Scott.'s Avatar
Nice work!! I just found my next project since I was having issues with my skinny 245s. I'm jealous of your 275s
Old 03-14-2016, 06:10 PM
sanyata
sanyata's Avatar
Great write up. Now I have a new project too..........
Old 03-14-2016, 11:56 PM
996TWINS
996TWINS's Avatar
+1. Thank you for your post. Good stuff as usual.
Old 03-15-2016, 12:00 AM
993GT
993GT's Avatar
nice write-up John!
these cars could use a bunch more front tire....I have 275 envy!
Cheers,
Rob
Old 03-15-2016, 01:16 AM
James88
James88's Avatar
Thanks for posting John, I've book marked this for future reference for when I go with 245/40/18 on front. From what I have read the 245 are a better match than 235/40 with 315/30 rears for AWD.
Cheers
Jim
Old 03-15-2016, 02:06 AM
911mhawk
911mhawk's Avatar
When does your how-to hod rod 996t come out?
Thanks again, I'll be installing my trans this weekend with a version of your cooler install.
Old 03-15-2016, 02:56 AM
powdrhound
powdrhound's Avatar
Thumbs up
You're welcome...
Old 03-15-2016, 08:28 AM
jumper5836
jumper5836's Avatar
wow 275's in the front. Whats that like for turn in.
Old 03-15-2016, 10:13 AM
powdrhound
powdrhound's Avatar
Don't know yet. Should be good though. We are currently setting up the car for 275/335s up from 245/305 so balance should not be affected much. I will post up data and lap time comparisons once we get it to the track.
Old 03-15-2016, 10:15 AM
jumper5836
jumper5836's Avatar
Old 03-15-2016, 10:19 AM
993GT
993GT's Avatar
I think the biggest advantage, for me at least, would/will be the effect on braking with current bias...I've been considering 335's as well, look forward to how you feel about clearance!
Old 03-15-2016, 10:21 AM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,247 Likes on 1,446 Posts
Cheers
Jim
245s fit on my car with no modifications.
Old 03-15-2016, 10:45 AM
powdrhound
powdrhound's Avatar
With the correct wheels 335s fit without issues but they need to be paired with a larger front to maintain balance. We did trim the sheet metal and the inside of the fender lip slightly near the aft end by the junction of the bumper to ensure clearance at low ride heights. None of this is visible from the outside obviously. Braking will be amazing for sure. I know I'm gonna be going through rotors like crazy with this set up as the Cup ABS already eats rotors at an alarming rate. Ugh...
Old 03-15-2016, 11:56 AM
Berra
Berra's Avatar
Wow, 275 front...talk about meat!! Could you post pics of that beast? Would love to see how it looks with those tires, and also in general.
Quick Reply: DIY: Modding front radiator brackets for big tires
