996 Turbo Forum 1999-2005
I broke something...
Old 02-26-2016, 04:01 PM
Rulez
Rulez's Avatar
Default I broke something...
So I'm in the midst of replacing my #16 check valve. I'm pulling on the hose that leads to the top of the plenum to remove it and snap, the nipple breaks off. Is that top piece of the plenum replaceable? Or is it part of the plenum, meaning I have to replace the whole thing?
Pics for reference:
Old 02-26-2016, 04:21 PM
Rulez
Rulez's Avatar
It comes off. It twists off. There is a little rubber o-ring under it. Anyone know a part number for this thing?
Old 02-26-2016, 04:44 PM
911mhawk
911mhawk's Avatar
Hope this helps, you may be in for some more work.
Old 02-26-2016, 04:55 PM
Rulez
Rulez's Avatar
Thanks man. Not looking too good for me, lol.
Anyone have a stock plenum laying around that they wanna get rid of? Or just the top piece?
Old 02-26-2016, 05:00 PM
fpb111
fpb111's Avatar
If it is too much $$$ or you need to drop the engine and pull the windshield to get at the whole assy. Get something like this and thread it in, anchor it with epoxy or the appropriate glue..
https://www.shopcross.com/product/pa...FRFahgodJiYEgA
or this
http://www.usplastic.com/catalog/ite...FZGQHwodPhYE8w
or this:
http://www.usplastic.com/catalog/ite...3057&catid=465
etc...
Old 02-26-2016, 05:07 PM
Rulez
Rulez's Avatar
Yeah thats also something I thought of. I just wanna be sure that it's gonna hold boost. I don't want to just band-aid it.
Old 02-26-2016, 05:21 PM
fpb111
fpb111's Avatar
This type has a nut to back it up??
Most of the plastic one have ~100+lb burst pressure. Probably high temp is more worry. Stick with brass.
lowest temp Nylon is 95C ~200F
Old 02-26-2016, 05:28 PM
911mhawk
911mhawk's Avatar
If you had any thoughts of dropping your engine for a bunch of fresh stuff, now's the time. Otherwise I'd be riggin that thing and back on the road. You can get it out by loosening the upper clamps and sliding the rubber sleeves inward.
Old 02-26-2016, 06:27 PM
jeanmarcboilard
jeanmarcboilard's Avatar
Time for a new IPD plenum?
Old 02-27-2016, 08:56 AM
Rulez
Rulez's Avatar
Usually I look for these opportunities to upgrade, lol. But I'd rather not drop $800+ on that right now.
Old 02-27-2016, 09:31 AM
32krazy!
32krazy!'s Avatar
i have an ipd plenum and 74mm t/b for 750$
Old 02-27-2016, 09:42 AM
Rulez
Rulez's Avatar
PM sent
Old 02-27-2016, 10:13 AM
Fishey
Fishey's Avatar
You can simply lower the motor to get better access.
Old 02-27-2016, 03:02 PM
Atrox
Atrox's Avatar
Can you just not source that part?
Old 02-27-2016, 07:59 PM
fpb111
fpb111's Avatar
No part number anywhere on it? Most plastic on these cars has a part number molded into it.
Quick Reply: I broke something...
