Shifter question...
#109
Less jerky/quieter - I find that a slightly taller gear has smoother operation in traffic, and, as I have no mufflers, I expect it to be quieter, this for my other half - I'm pretty deaf, and thus, why I removed the mufflers....
When I drive my friends 991.2s, I don't drive it in auto mode, I use the paddles and I find the taller gear more desirable in the city.
#110
I don't understand the "less jerky" part.
As for the noise, I understand more about that. If I were in your shoes (hearing wise) I would do all I could to protect my hearing from further loss (read: reduce the noise your exhaust makes). I understand that not having mufflers allows you to better hear the exhaust, but that db level may also be doing further damage to your hearing when your other half is not with you.
#111
Interesting.
Hearing is a little more complicated, I have a decidedly mid range flat spot - that just happens to be where most of us speak - it was hereditary and there is no fix. Fortunately, it doesn't get worse.
#112
If I were in your situation I'd just stay with the stock gearing and choose a gear that satisfied the other half. Then when she's not with you the better stock gearing acceleration is available.
#113
You likely just need more practice with the set up. I also deal with almost all of those same things; I have the 13s + LWFW + X73 + same 1st gear, and "jerky" operations are not anything I experience. I may not deal with as many crappy roads, but I haven't driven in your area enough to make a good comparison to Georgia roads.
Exposure to high dB doesn't ever help one's hearing.
I do not find it super loud in the car, unless it is way up on the revs - I have no problem talking/hearing at a nice 60/70mph cruise.
#114
Given the right situation I have no issue with motoring along at as low as 2000 RPM in 3-6 gears. I obviously will motor along below 2000 RPM in 1st or 2nd if traffic or mood produces slow speeds.
#115
The manual clearly states that if the engine drops below 1500rpm, shift down to compensate.... previous guy did not read the book...
