DV Upgrade Reccomendations
Hello all,
Recently purchased a 01 996TT (loving it) installed a K&N Filter and bought a Cobb Accessport V3. I'm saving my extra modding money for a SpeedTech X-Pipe, but wondering on people's thoughts on replacing the stock Bosch diverter valves.
Is it worth replacing them if the stock ones aren't honking? Before the Cobb stage 1 93 tune I was able to get .7 - .8 Bar peaks and now getting 1 - 1.1 under WOT.
In people's experience will replacing the DV help maintain that boost level longer, or possibly give a higher boost level before I upgrade the exhaust?
Any experience with the Agency Power DV's?
I'd stay stock or 710N if you aren't running big boost/having reliability issues.
My '2 came with EVOMS DV's and they have been good as well, but if it was money money/purchase, I probably wouldn't purchase them for my application...
my car has also been running evoms dv's for well over ten years absent issue. thats the thing about "many" aftermarket dv's is their capacity to outlast oems. but if you dont go with evoms or agency power or baileys or whatever? and replace with oem? get the 710n. they are sturdier also than the original 710a bosch.
would really like to read a review of the accessport! a cobb tune is on my to do list but the v3 may be a bit too rich for my blood or "needs". congrats, i bet THAT woke her up!
Hello all,
Hey... we are neighbors... almost I'm just up 85 a little north of Gastonia, NC.
Just My .02 but I wouldn't spend the money on new DV's if they are not giving you issues. I'd spend it on plugs, coil packs, ICs etc., again if they are not bad.
BTW I also have a Cobb now (switched from another tune) and the SpeedTech 3" Competition X-Pipe. If you are interested in hearing it "live" before you buy PM me and we can get together.
Thanks all for the feedback. I think I'll hold off then on the DV's and keep saving for the X-Pipe, although I just took it to the shop with a leaking tranny at ~ $1500 it might be a bit longer...
I can definitely do a little write up, though I didn't have it very long without it so I'm probably not the best reviewer, though I did notice an immediate increase in low to mid end torque. Once I get it back from the shop I can de-flash it and do a better comparison.
Awesome @mxracer! I'd love that. Videos are great, but it's always hard to tell the volume without being in person. I'll shoot you a DM once I get it back from the shop and set up a day to shoot up there. I work remotely so I could work from a coffee shop for the day up there.
but ( possibly wrong thread?? sorry ( as usual! ) but PLEASE post up your take on the v3 once you've gotten to "know it" as many of us see it and drool lol.
btw.. if i didn't get a chance prior to this to say "welcome"? i have now! i notice you're relatively new and have posted cool stuff already! so cheers.
..and PLS post about the cobb v3! when its "time"! TIA!
Just for the record, so to speak, the reason folks replaced their DV's originally was the POSSIBLE deterioration (or rupture) of the rubber components inside the DV. It was thought (or maybe still is), that if rubber diaphragm ruptures, the failing pieces could wind up where you don't want them and cause potentially lots more damage. It was never a performance upgrade, just a preventive maintenance "fix".
Porsche replaced my DV's (with Bailey's, under warranty) because they were "honking". I believe the honking was caused by a tear in the rubber. My recollection of way back when was that people replaced their DV's s because of tears in the rubber and the honking that caused, and not because DV pieces were breaking loose, or might break loose (although pieces may well have broken off. I just don't remember hearing about it).
Get rid of that K&N the oil will foul your MAF sensor ad cost you! The stock airfilter is pretty free flowing, or if you must upgrade use a dry performance filter! Its only a matter of time till that MAF goes out on you!
My stock dvs went bad replaced them with champion dvs. I would not replace till they go bad.
