What causes exhaust drone
I love exhaust videos where people film a pull from the front and then let off when the car passes the camera
Lol herp derp.
Make your own helmholtz chamber. Doesn't matter where it is..comes down to packaging it.
Lol herp derp.
It seems the majority of videos attempt to illustrate how the car sounds either via a microphone attached right next to the exhaust, or via a microphone beside the road as the car drives by.
When I was shopping for an exhaust I was interested in how it would sound inside the car, not how it would sound to people outside the car.
I'm with you on that. It seems the majority of videos attempt to illustrate how the car sounds either via a microphone attached right next to the exhaust, or via a microphone beside the road as the car drives by. When I was shopping for an exhaust I was interested in how it would sound inside the car, not how it would sound to people outside the car.
Yes, do the firewall and parcel shelf - both behind the rear seats. Just unscrew and remove the seats, pop out the Bose speaker grilles, remove the two allen bolts holding the Bose in place, slide it forwards gently and unclip the electrical connector (the only fiddly bit as it has a little retaining lug but it is pretty solid so little chance of breakage). There may be a couple more simple brackets to remove IIRC then just pull all the foam-backed carpet trim sheets out and get to work. Those are all just pressure fit, with the parcel shelf one wedged in fairly tightly so I think I just pushed it up and worked underneath it.
If you track or canyon your car you'll want to minimise the weight you add, hence the tip to concentrate the most layers towards the middle of those big panels. I stacked them concentrically like a contoured hill covering about a quarter of the surface area then put a single layer over the top to tidy it and provide a little extra damping. Figured there was no point adding more weight by putting lots of layers all over everything as it doesn't primarily isolate or absorb sound. As I said, with you being an engineer I'm sure you know it already, but in case this doesn't make sense to anyone, it basically works in the same way as sticking a pound of softish butter to the middle of a drum skin, damping vibrations and lowering their frequency down to where they no longer resonate in an irritating way.
Just reverse the access procedure to put it back together, but its like Lego really so will be dead obvious.
you guys that talk about the way in which someone makes a fkn video of the sound of their exhaust as if they were some kind of an autuer, rather than just someone making an impromptu video with probably a handheld phone or something are ridiculous and pompous a**es.
"i hate the way they hold the microphone" etc etc. its laughable. you guys should try using the sphincter phone, it's a handheld mic and will capture the most mellifluous tones ever. LOL
hilarious. it's a sound clip of an exhaust. not a film noir event. LOL. incredible.
That reminds me - must finish auditioning directors for my next run through the tunnel
More seriously, I guess they're just checking out those exhaust vids in the hope of confirming that the $2 to $6K they're sending off for one may have something like the desired effect. But of course that's not usually what those making the vids were aiming towards really.
Maybe for some here it's like going to a wine tasting only to find that all the bottles were opened the week before?
its the same as dolts who make an intake video, of the car stationary revving.
bruh, intakes need load. get moving.
In my experience the way unobtainium does it is right. I do not believe their resonator (tubes) are packed. Different tube length cancels different frequencies. It is a bit of trial and error on each model car. I built some a long time ago for an old mitsi. I would say (and will be doing) buy an unobtainium exhaust and be done with it. They seem to have a drone-less exhaust for our cars nailed.
do it right then . at least get a shot of it under load driving by. Filming it coming towards the camera is fine if the person driving keeps accelerating by. But it seems so many are off the throttle before that point, so you get no clue to what it sounds like under load.
as for me? by way of example, i just listened to jamess88 here for whom i have a fondness and respect for as a person, even if he, like myself, is possibly not the most technically knowledgeable person habitating the forums, but he speaks in ways that i readily understand. as do you. then i spoke with the US distribber who is my friend, and i was "sold", but a pre purchase vid of ANY kind would've been helpful perhaps, but i sure wouldn't criticize someone for WHERE OR HOW, THEY HELD THE DAMN PHONE!?! i mean c'mon.. LOL
so at the risk of repeating myself? i just think that criticizing someones ( ANYones "exhaust sound clip methodology" is about as pompous as can be, but then i DID consider the source, and it was not you. so forgive me if i offended you with my usual harsh and somewhat ascerbic tone. i may drone, but my kline doesn't HAH
Off topic OP I know that exhaust came with your car but I'm very intrigued. I haven't found decent exhaust I'm willing to spend money on quite yet and that setup has a lot of potential.
Thread necromancy
So I went and got a cheap exhaust system - Manzo CBS-PC09T. It brought me to this thread about drone...
I like the idea of installing a Helmholtz resonator pipe on each side, if there's space. I'm going to be checking with my local muffler shop. The trick is getting the length of the pipe right to match the resonant frequency. I contacted the guy at Unobtainium, and not surprisingly, he didn't want to give me the dimensions of the resonator pipe. The name of his company is "unobtainium", after all.
So I figure I can either do a trial-and-error system, starting with some math to figure out the wavelength @ the resonant frequency and work from 1/2 that or whatever (since I think 120Hz is something like 1.5 meters ??) ... OR... get some free labor in the form of Automotive Engineering students wanting a summer project...
I have an Unobtainium 3" flow through exhaust with helmholz resonators and can unequivocally say there is zero drone. None. Zilch. Really amazing. My RUF exhaust had some and even a stock exhaust has a trace around the 2500 range.. I've tried a speed tech 2.5 and a Europipe loud both of which droned to my ears which are particularly sensitive. The EP loud on a K24 car was bad. Out of all the traditional aftermarket exhausts I tried, an inconel 70mm Kline had virtually no drone but was very quiet as a byproduct. That was a great exhaust but muted. If you can get the length and diameter of the helmholz pipes just right, say goodbuy to drone even on a loud 3" flow through exhaust. Its simple proven science that can not be disputed. All other methods simply attempt to mask drone which provides poor results at best.
